On gear drives running with pitch line velocities below 0.5 m/s so called slow speed wear is often observed. To solve
some problems, extensive laboratory test work was started 10 years ago. A total of circ. 300,000 h running time on FZG back-to-back test rigs have been run in this speed range.
1984 by the author
In response to Ed Uberts letter, we have come a long way in gearing since WWII. The Europeans do use long
addendum pinions in many cases. This modification does improve load capacity, sliding conditions and the working life of a gearset. When modifying a pinion tooth it is
necessary to modify the gear tooth or adjust the center distance accordingly but we will leave that to the designers.
