Resonant response
Dear Editor:
Carburized and hardened gears have optimum load-carrying capability. There are many alternative ways to produce a hard case on the gear surface. Also, selective direct hardening has some advantages in its ability to be used in the production line, and it is claimed that performance results equivalent to a carburized gear can be obtained. This article examines the alternative ways of carburizing, nitriding, and selective direct hardening, considering equipment, comparative costs, and other factors. The objective must be to obtain the desired quality at the lowest cost.
Taxes may be one of the only two sure things in life, but that doesn't make them popular. Nobody is happy to pay them, and the bigger the amount due, the unhappier the taxpayer. Conversely, politicians know that coming out in favor of a tax cut is the equivalent of voting for apple pie and motherhood. It's a sure-fire success at the ballot box.
A widespread weakness of gear drawings is the requirements called out for carburize heat treating operations. The use of heat treating specifications is a recommended solution to this problem. First of all, these specifications guide the designer to a proper callout. Secondly, they insure that certain metallurgical characteristics, and even to some extent processing, will be obtained to provide the required qualities in the hardened gear. A suggested structure of carburizing specifications is give.
For many years chromium has been a popular alloy for heat treatable steels because of its contribution to hardenability more than offsets its costs. As a consequence, it is specified in such high-tonnage steel grades as the 5100, 4100, and 8600 series; and, as a result, about 15% of the annual U.S. consumption of chromium is used in constructional alloy steels.
