Rego-Fix USA will spotlight two new tool clamping/unclamping units for the company’s powRgrip toolholding system and a new spindle drawbar force testing tool at IMTS 2024 in Booth 431822. The new units are the PGA (automatic) 9500 and the powRgrip Single, while the ForceMaster tool is the latest addition to the company’s family of metrology products.
Powerful and Intuitive Automated Configuration Speeds Deployment of Robotic Machine Cells
September 7, 2022
D:PLOY automatically discovers and configures all the components in a robotic cell—including any leading collaborative or light industrial robot arm and tools—while also integrating external I/O from sensors and machines. D:PLOY will be available for all common robotic applications, making deployment up to 80% faster.
Hyperion Materials & Technologies manufactures hard and super-hard materials for a wide variety of industries and applications, including cemented carbide blanks for gear cutting and hobbing. Hyperion will showcase its gear tool blanks and many other products and manufacturing solutions at IMTS 2022, Sept. 12 to 17 in Chicago.
The tedious task of loading and unloading parts into machines has long been a bread-and-butter application for cobots gaining significant traction in the industry. With its 1,750 mm (68.9 in) reach and 20kg payload (44.1 lbs.), the new UR20 from Universal Robots greatly expands automation opportunities such as the ability to reach further into machines, tend several machines in the same cycle, and handle 25% heavier parts. Despite being UR’s heaviest robot, the UR20 is the lightest cobot in its class, weighing only 64kg (141.1 lbs.) making it both a versatile technical tool and a manual laborer.
The new ANCA MX7 ULTRA can manufacture large volumes of precision endmills and other cutting tools. The minute size of a micron is beyond the human eye, but by moving from micrometers to nanometers, ANCA will offer the highest accuracy and quality in a cutting tool in the market.
Robotic machine tending, collaborative mobile robotics and other technologies for optimizing process efficiency and boosting productivity
August 30, 2022
At IMTS 2022, Stäubli Robotics will exhibit advanced robots used to help manufacturers meet new challenges and changing market demands across a range of industries worldwide. The company will present live demos recreating real-world applications in industrial manufacturing, with an emphasis on robotic machine tending.
Workholding solutions increase throughput which generates uptime because they greatly reduce setup and changeover times. Operators can change workpieces in a highly repeatable manner which significantly increases the quality of the finished part. The primary function of streamlining production is to develop a workholding solution that optimizes the machining of multiple parts at once while maintaining tight tolerances. Below you will find a cross-section of companies that will be showcasing their approach to workholding systems at IMTS from Sept. 12–17 at McCormick Place in Chicago.
