L&L Furnace Shipped to Goodrich Facility June/30/2009
A model FB series fiber-lined box furnace was shipped to the Goodrich Aerostructures' Mexicali production facility by L&L Special... Read More
ALD-Holcroft Expands Product Line June/8/2009
The MonoTherm single chamber vacuum furnace, a product known on the global market through ALD Vacuum Technologies of Hanua, Germany, is a... Read More
Pit Furnace Line Addition Doubles Plant's Capacity June/8/2009
Elterma S.A. commissioned two electrical PEGat-1000/18x30 pit furnaces and a G-4000-ET atmosphere generator for a Spanish manufacturer of... Read More
Solar Awarded Order for R&D Vacuum Carburizing Furnace June/8/2009
A top loading model VTC-714 R&D furnace by Solar Atmospheres was ordered by a mid-Atlantic, aircraft industry manufacturer for proces... Read More
Economy Tooling Line Creates an Affordable Start for Novice Router Users April/14/2009
Techno, Inc. CNC Cutting Tools has announced the start of an economy tooling line of CNC router bits for use by novice CNC router users t... Read More
Face Mill Withstands Heavy-Duty Operations April/13/2009
The CoroMill 360 from Sandvik Coromant is a 60-degree face mill constructed with through-hardened steel for strength in demanding applica... Read More
Slender Drive Angle Head Machines Bores More Flexibly April/23/2009
BIG Kaiser's Slender Drive Angle Head features a reduced body that is capable of 90-degree cutting operations inside small bores. The... Read More
Electrically-Heated Quench Tank Cures Products Post Heat-Treat April/6/2009
The Number 974 insulated quench tank from the Grieve Corporation is electrically-heated to 200 degrees for heating mineral oil to cure me... Read More
Low-Foaming Cutting Fluid Resists Bacterial, Fungal Growth May/8/2009
The KoolRite 2365 semi-synthetic cutting fluid from JTM Products, Inc. was designed for high-pressure applications that typically have fo... Read More
Archive of Past Articles
