SDP/SI Publishes Catalog, Redesigns Website May/2/2008
The 96-page "Handbook of Fairloc Components, , The Integral Fastener, D243" from Sterling Instrument and Stock Drive Products, ... Read More
Haas Mini Mill 2 Extends Travels April/24/2008
The Mini Mill 2 from Haas Automation is a CNC machining center featuring extended travels of 20" x 16" x 14" (xyz); this... Read More
GH Gear/Raceway Hardening Machine Handles Large Bearings More Productively April/24/2008
GH Induction Group recently shipped a new design gear/raceway hardening machine capable of hardening gears and bearing raceways up to 3... Read More
GROB Horizontal Machining Center Multi-tasks Precisely April/24/2008
The machine tool division of GROB Systems Inc. introduces the G350 horizontal machining center that is capable of production using up t... Read More
Sumitomo Drive Technologies Introduces Food-Grade, High-Pressure Washdown Hyponic Right Angle Reducer March/24/2008
Sumitomo introduces its newest Hyponic® product variant designed for the food industry and high-pressure washdown (HPW) applications. Dev... Read More
alpha & Wittenstein Increase Measurement Accuracy February/18/2008
New sensor technology from alpha & Wittenstein integrates torque and force sensors into the housing of servo gear reducers, enabling ... Read More
VAC-U-MAX Industrial Vacuum Cleaning System Extracts Fluid and Solids February/18/2008
Powered by compressed air, the VAC-U-MAX 55MW filters liquids and removes metal chips from coolant in order to increase coolant life and ... Read More LED Light Ring Illuminates Without Heat or Fiber Optic Cables February/13/2008
NovaTech, Inc. has introduced an LED light ring for laser- and micro-welding microscopes that provides illumination without heat or fiber... Read More
SafeTap Plus Provides Safe and Clean Working Environment February/13/2008
ITW Rocol recently unveiled a new water-based tapping fluid with a custom blend of synthetic additives that provide cooling properties wi... Read More
Digimar Height Gage Provides Smooth Movements for Positioning February/13/2008
The Digimar 817 CLM height measuring instrument from Mahr Federal will be featured at WESTEC 2008 from March 31–April 3. The gage o... Read More
Helix Wiper Geometries Reduce Vibrations and Increase Tool Life February/13/2008
Seco Tools Inc. recently unveiled Helix wiper geometries for operations in high-feed machining of case hardened steels where standard wip... Read More
FA Advance Wire EDM Series Extracts Data Directly Within Control February/13/2008
MC Machinery Systems, Inc. introduces its new FA Advance Wire EDM series featuring an M700 series control. The Windows-based system with ... Read More
VMC Infimatic Control Compatible With Standard G Codes and Part Programs February/13/2008
MAG Fadal recently announced its FX series will be available April 2008 with the Infimatic Freedom NC2000, a digital control for metal-cu... Read More
PG-Series Bore Gages Mount Directly to Machines February/13/2008
With no need for electrical or air connections, Sunnen’s PG-Series Bore Gages can be mounted directly to machining stations, making... Read More
Blaser Swisslube Fluid Designed for Long-Term Sump Life February/6/2008
Blaser Swisslube, Inc., introduced BC 230, a liquid tool providing advanced stability and long-term sump life that improves machine uptim... Read More PcTime! Released for PalmOS and Windows Mobile Devices January/23/2008
InfosystemsPro LLC announces the release of PcTime! for PalmOS and Windows Mobile devices. PcTime! makes it easy to calculate production... Read More Wera Profilator Introduces Scudding Process January/11/2008
Introduced for the first time at EMO 2007, the Scudding process is a continuous cutting operation that uses a tool design similar to a he... Read More
Bodine Electric’s Low-Voltage Products Counter High Energy Costs December/19/2007
With rising energy costs and environmental concerns, Bodine Electric recently announced the release of a low-voltage product line. Bodine... Read More Ultrasonic Tanks Aim to Clean-Up Industrial Manufacturing December/7/2007
Ultrasonic tanks by Omegasonics assist in the process of toxic parts cleaning in all industrial machining applications. According to the ... Read More Stafford Offers Mounting Collars with Multiple Bore Designs December/7/2007
Stafford recently introduced a universal mounting collar that can be supplied with different bore designs to fit rail mounts and other de... Read More
Guyson Introduces Blast Cabinet December/6/2007
Guyson’s single-spindle blast machine allows 360-degree coverage by timed blast- and blow-off cycles, performed as a workpiece rota... Read More
LMC Introduces Large Atling Steady Rests December/6/2007
Designed to fit any CNC or conventional lathe, the LMC Atling self-centering steady rests feature three new models—the LZ90-360, LZ... Read More
Rex-Cut Introduces Interleaf Flap Disc December/4/2007
The Rex-Cut Fusion Flap Disc combines two types of abrasive layers for one-step grinding and finishing. According to the company’s ... Read More
Philadelphia Gear Introduces CORE Online December/4/2007
Continuous Oil Rescue Equipment (CORE) filters, launched as an alternative to traditional barrier filtration techniques by Philadelphia G... Read More Lenze Expands Range of Geared Servo Motors November/15/2007
The MC range of Lenze motors has recently expanded to cover more than 7,500 selections with in-line or right-angle gearboxes. According t... Read More Gleason Debuts Opti-Cut Tools for Gashing, Shaping and Hobbing November/9/2007
A new family of cutting tools was recently introduced by the Gleason Corporation for the gashing, shaping and hobbing of gears. This new ... Read More Dontyne Debuts GATES Software for its Gear Production Suite November/9/2007
Dontyne Systems, a U.K. company founded by Michael Fish and David Palmer, recently unveiled a new software program for its Gear Productio... Read More
LMC Workholding Introduces Neidlein Face Driver November/2/2007
LMC Workholding recently unveiled its Neidlein FBS MK5 model face driver, designed specifically for hard tuning or grinding operations. T... Read More
ITW ROCOL Launches Food-Grade Lubricant November/2/2007
ITW ROCOL recently announced the launch of a unique food-grade lubricant called Accu-Lube FG-2000. According to the company’s press... Read More
NILES Launches ZP B Hybrid Machines November/2/2007
Built to meet the demands of large gear grinding, Niles recently launched the ZP B hybrid machine. The machine is designed for the comple... Read More
Faro Unveils Advanced Portable Computer-Aided Measurement Arm November/2/2007
Faro Technologies Inc. recently announced the release of the Quantum FaroArm—the first eight-foot arm proven to measure accurately ... Read More ADCOLE Offers High-Speed Crankshaft Gage for Better Accuracy November/2/2007
A new high-speed, in-line, automatic crankshaft measurement gage for production environments that provides sub-micron accuracy has been i... Read More
Technosoft Drives and Motors Provide More Intelligence to CANopen November/1/2007
All Technosoft intelligent drives and motors now support CANopen. Embedding motion control, drive and PLC functionalities in a single com... Read More
KAPP KX 500 FLEX Adds Multi-Station Turn Table and Twin Spindle Dresser October/23/2007
The KAPP Group has introduced the KX 500 FLEX Gear Center. Like other KX models, the KX 500 FLEX offers continuous generating grinding, d... Read More
Emag’s New Machining Centers Apply Simultaneous Five-Axis Machining August/30/2007
EMAG’s BA S03 vertical machining center is designed as a monobloc enclosed on three sides and topped by a gantry and combines a min... Read More
Sunnen’s SV-310 Bore Sizing System Designed for Small Engines, Compressors August/21/2007
Sunnen's new SV-310 vertical CNC honing system combines a choice of tooling options, large work envelope, and 762mm/30" str... Read More
Morgan Advanced Ceramics Introduces New Coatings from the Racing Industry August/14/2007
The Diamonex Products division of Morgan Advanced Ceramics (MAC) introduced its Diamonex® Diamond-like Coatings (DLC) for the pe... Read More
Parker Hannifins Actuators Eliminate Need for In-House Positioning System August/9/2007
The PROmech actuators from Parker Hannifin are designed for analytical, OEM and lab instrument manufacturers.The actuators come completel... Read More Trico Corp.s Dispensers Lubricate Critical Parts During Machine Operation August/9/2007
Trico’s new line of Streamliner grease dispensers are an alternative to manual lubrication. These units are designed for applicatio... Read More
Meister Abrasive Develops External Abrasive Product Line August/14/2007
Meister Abrasives USA, recently developed a line of external abrasive products.Bruce Northrup, general manager of Meister Abrasives USA, ... Read More
Toyoda Machinerys Inverted Vertical Turning Center Introduced at CMTS August/8/2007
Toyoda Machinery will introduce its newest machine line at CMTS from October 15-18 in Booth 3600 with its new Canadian distributor Elliot... Read More
PICO Chemical’s New Solvent Replaces Hazardous Materials for Gear Cleaning August/8/2007
hemical Corp released its Pico Solv NPB as a new technology chlorine-free solvent cleaner that is manufactured specifically o replace haz... Read More
alpha gear drives Introduces New Gearhead August/7/2007
The in line basic precision alphira product from alpha gear is packaged in a lightweight aluminum case and offers power-dense and mainten... Read More
Koepfer America Launches Large Capacity CNC Hob Sharpening Machine August/7/2007
Koepfer America developed the new KFS250 CNC hob sharpening machine, which is based on its KFS100 series. The KFS250 series h... Read More
Sensor Development’s Latest Model Measures Small Reaction Torque Level August/6/2007
The Model 01165 small flange reaction torque sensor from Sensor Development is designed to measure small reaction torqu levels using flan... Read More
LMC’s New Face Drivers Provide Tighter Tolerances August/2/2007
LMC Workholding introduced its new Neidlein face driver,s providing tighter tolerances for applications including hard turning, grinding,... Read More
StarragHeckert’s Machining Centers for Large-Scale Gear Housings Improve Productivity August/16/2007
Flender Guss GmbH & Co. KG manufacturers of large scale gear housings for wind power plants, recently discovered its rate of or... Read More
Bodine’s New Gearmotors Deliver Twice the Torque of Popular Motor/Gearhead Combinations July/26/2007
Bodine Electric's CG gearmotor, an extra-rugged line of variable speed AC inverter-duty and permanent magnet DC gearmotors, was devel... Read More
Grieves New Oven Burns Hydrocarbons from Machined Metal Parts July/19/2007
The new No. 875 oven from Grieve is a gas-fired, 1600ºF (871ºC) specialty furnace from Grieve, currently used for burning off h... Read More
Midwest Motion Introduces New Gearmotor July/19/2007
Midwest Motion Products released a new DC Gear Motor, the Model No. MMP TM55-24V GP52-124. Accepting any 24 Volt DC source, includin... Read More
Marposs Introduces Wireless Bore Gauge with Optional Inductive Battery Charger July/19/2007
Marposs Corp. will present its new M1 Wave wireless bore gauge with an optional inductive battery charger in at South-Tec 2007.Equi... Read More
Drake Manufacturing Buys Wenzel Gear Checker July/23/2007
FOR IMMEDIATE RELEASE For further information, Contact: Jim VosmikPhone... Read More
LMC Workholding Offers Large Size Chuck July/11/2007
LMC Workholding offers large size power chucks for high-speed applications and extra large thru-holes for large bore lathes. LMC of... Read More
Hainbuch Produces Large Mandrel With Significant Clamping Range for China July/9/2007
Hainbuch GmbH produced a workholder that weights 1.3 tons and features a clamping range of up to 420 mm.According to the company's pr... Read More
Weiler Publishes Brochure Detailing Gear Deburring Capabilities July/9/2007
Weiler Corp.'s six-page technical brochure on gear deburring with power brushes explains the importance of deburring ... Read More
Pico's New Technology Cutting Oil Replaces Chlorinated Paraffin-Based Fluids August/8/2007
Pico Chemical Corp. announced a chlorine-free and blue cutting oil for hard-to-machine stainless and titanium alloys. The... Read More
mG miniGears Installs Furnace Loading System June/25/2007
mG miniGears installed a furnace loading system in its powder metal department to avoid defects, especially for gears where small damage of the... Read More Zeitlauf’s Angular Gearing Offers Worm Gear Drive/Bevel Spur Gear Alternative June/21/2007
The EtaCrown concept from Zeitlauf offers an energy-efficient alternative to worm gear drives and bevel spur gears.According to the compa... Read More
Brevini’s Gearbox Operates Quietly for Rubber Sheeting Manufacturer June/21/2007
When Primasil, a U.K.-based independent silicone compounder and manufacturer of non-silicone rubber sheeting, discovered its main drive g... Read More Kapp's Rotor Grinding Technology Improves Efficiency by 30% June/15/2007
The Kapp RX 59 allows the rotors used in air compressors to be manufactured on the machines by using a high precision grinding process.Ro... Read More Gearmotors Built for High Torque Applications June/6/2007
The AKM gearmotors set from Heason Technologies combines the torque density from the company's line of servomotors with its planetary... Read More Koepfer's Heavy Duty Hobbing Machine Offers Extended Part Size Capacity June/6/2007
The Heavy-duty Model 300 from Koepfer America provides for a bigger part diameter, coarser diametral pitch, and bigger hob capacity than ... Read More
Drakes New Mini External Thread Grinder Targets Small Parts Makers May/31/2007
With a work envelope of 100 mm x 100 mm, Drake's GS:TEM mini three-axis thread grinder is aimed at higher volume, precision threaded ... Read More
Danfoss’ New VLT Drive Handles Extended Motor Control Requirement May/30/2007
Danfoss Drives' VLT® AutomationDrive variable
frequency drives are now available in the 75-100 HP power range at 380-480/500 VAC. T... Read More Midwest Motion Introduces New Gearmotor May/24/2007
Midwest Motion Products announced the availability of the MMP-TM55-12V Gpk52-124 gearmotor.
The motor accepts any 12-volt VDC source, ... Read More
Source Engineering Introduces Planetary Gearmotors for OEM Applications May/24/2007
Source Engineering introduced planetary brush and brushless gearmotors for OEM applications. Gearmotors are best suited to applications r... Read More Bonfiglioli Updates Parallel Shaft Series and Bevel-Helical Series Gearboxes May/31/2007
Bonfiglioli recently presented five new sizes in the HDP parallel-shaft series and HDO bevel helical series that was first introduced in ... Read More
Renold Introduces Interchangeable Range of Gearboxes and Couplings May/24/2007
Renold will exhibit its SMXtra interchangeable range of gearboxes and fluid couplings, for quarrying applications, at the Hillhead Exhibi... Read More
ZF’s Right-Angled Gearheads Open Door for Luxury Multimedia Pod May/24/2007
The SWG gearheads from ZF offer a smoother alternative to screwjack-based door control systems used in the latest luxury media experience... Read More
Vectron’s Viscosity Sensor Detects Oil Change in Gearbox May/29/2007
The low shear ViSmart™ viscosity sensor from Vectron International was recently used to collect real-time viscosity data in an oil-aging ... Read More
Moventas Launches Wind Turbine Condition Management System May/24/2007
Moventas introduced its latest wind turbine condition management system at Hannover Messe 2007.
The system focuses on the gearbox and a... Read More Source Engineering Introduces Planetary Gearmotors for OEM Applications May/31/2007
Source Engineering introduced planetary brush and brushless gearmotors for OEM applications. Gearmotors are best suited to applications r... Read More Schreiner ProTech Introduces PTFE Membrane May/18/2007
Schreiner ProTech today announced the introduction of their new PTFE (polytetrafluoroethylene) membrane, an air-permeable and waterproof ... Read More
Emags Newest Vertical Turning Centers Offer Quicker Automatic Workpiece Changeover April/3/2007
The VL series vertical standard turning machines from Emag are universal production tools with a small footprint and automatic workholdin... Read More
Oil-Rites Redesigns Broad View Level Gage March/28/2007
Oil-Rite Corp. re-designed its broad view level gage to reduce the number of unique components.
Liquid level gages are used in various... Read More ZFs New Gearheads Designed for Broad Range of Servo Applications March/27/2007
ZF launched a new range of compact WTE (WT Economy)single-state right-angled gearheads for OEM designers and maintenance engineers.
A ... Read More Midwest Motion Releases New Gearmotor March/15/2007
Midwest Motion Products announced the release of a new DC Gear Motor, the Model No. MMP-TM55-90-12V GPk52-124.
Accepting any 12 Volt D... Read More Weiler Publishes New Brochure March/14/2007
Weiler Corp., an ISO 9001 certified manufacturer of wire brushes, Nylox nylon abrasive filament brushes, abrasives and maintenance produc... Read More
Philadelphia Gear Offers Two Versions of Continuous Oil Rescue Equipment March/5/2007
Philadelphia Gear Corp. announced the availability of two versions of the company's proprietary CORE Continuous Oil Rescue Equipment.... Read More New Brevini ?High Power? Series Combines Epicyclic Gear Design with Modularity March/2/2007
Brevini's new ?High Power? Series combines the highly efficient epicyclic gear design of Brevini's recently introduced ?S? Series... Read More
New Parallel Shaft Gearmotors from Sharq Motion Offer Backward Compatibility March/5/2007
The new Sharq 207 series parallel shaft gearmotors, designed as direct drop-in replacements for many high volume OEM applications are the... Read More
Wheelabrators Airblast Peening Technology Credited with Start-Up of Two Custom Machines for Turbine Engine Components February/27/2007
The Wheelabrator technology for automated airblast peening equipment is credited with the recent start-up of two custom machines at a rep... Read More duMonts Keyway Broach Sets Cuts Complete Range February/21/2007
A heavy duty set of keyway broaches, bushings and shims designed for cutting a complete range of keyways from 1/8" to 3/4" without duplic... Read More
BIG Kaiser Precision Toolings New Indexable Drill Design Provides Deeper Boring Depth February/19/2007
BIG Kaiser Precision Tooling introduces its newest indexable insert drills.
According to the companys press release, the new de... Read More Mahr Federals New Portable Finish Gage Includes USB Interface February/20/2007
Mahr Federal will feature its new Pocket Surf PS1
portable surface finish gage at the EASTEC 2007 Exposition.
Based on Mahr Federal... Read More
Schunk Releases New Electrical Miniature High-Speed Parallel Gripper February/14/2007
Schunk Workholding's miniature high-speed parallel gripper (MHP) is the two-finger counterpart to the centric gripper SMG.
Accord... Read More Slater Tools Introduces Rotary Broaching Tool Holder February/14/2007
Slater Tools Inc. released a new, adjustment-free rotary broaching tool holder designed for Swiss- type machines.
Slater's new adj... Read More Holroyd?s Plated CBN on High-Rigidity Edgetek Machines Reduces Process Times with Single Lift and Setup February/14/2007
Holroyd's Edgetek machines are produced with high-power/high-speed spindles that optimize the use of plated CBN wheels at surface spe... Read More Newage Testings Microhardness System Contains Multi-Specimen Fixture and Positioning Tables February/14/2007
Newage Testing Instruments' introduced the new model CAMS-MSO multi-specimen microhardness testing system.
The system can handle... Read More Gleasons Newest Threaded Wheel Grinder Delivers Faster Floor-to-Floor Times for Cylindrical Gears up to 300 mm February/13/2007
The 300 TWG from Gleason Corp. is designed to deliver fast floor-to-floor times for grinding of cylindrical gears with a diameter up to 3... Read More
Marposs Introduces Gauge Head for In-Process Grinder Control at Eastec February/26/2007
Marposs Corp. will show its new NanoUnimar ultra-compact gauge head for in-process grinder control in Booth #3006 at the EASTEC APEX 2007... Read More
Ingersoll Cutting Tools Introduces Insert and Tooling Family February/7/2007
Ingersoll Cutting Tools introduces its Hex-Turn family of inserts and holders.
According to the companys press releaes, the 12... Read More
Cincinnati Machine Introduces CNC Tape Layer Technology February/6/2007
Cincinnati Machine's new CHARGER Series of machines were designed to improve upon the technology and productivity of CNC composite ta... Read More Rex Cuts Mounted Points Reach Deep Into Channels with Little Vibration February/6/2007
A line of mounted available in various shapes and sizes to fit into channels and other contoured spaces for repairing and maintaining mol... Read More
Dapra Expands Toroid Tool Line January/26/2007
Dapra Corporation recently added 12 new shell mills in ODs from 2" through 8" to its high-performance Toroid cutting tool line.
For m... Read More GEARCALC Software Officially Released January/26/2007
GEARCALC, a software program for sizing and rating cylindrical gears, now offers demos for downloading.
Three parts offer algorithms ... Read More Hardinge Debuts Turning Center at Westec January/24/2007
Hardinge introduces its SR-Series multi-tasking turning center, utilizing a three-jaw chuck.
According to the companys press re... Read More
Command Tooling Introduces New Presetter for Precision Machining February/20/2007
Command Tooling Systems new Digiset 6 presetter provides increased productivity and streamlined setups for precision machining.
... Read More
Inductoheats Heat Treating System Compatible with Numerous Power Supplies January/16/2007
The InductoScan modular heat treat system from Inductoheat is designed to increase versatility, reduce maintenance and installation cost... Read More
Koepfers Versatile MZ 130 Provides Same-Setup Gear Hobbing and Worm Milling January/10/2007
Koepfers MZ130 hobbing and worm milling CNC machine from Monnier + Zahner was designed with versatility and ease of use in mind.
... Read More Marposs Announces Plans to Release New Probing System at WESTEC January/16/2007
Marposs Corp. will showcase its new Mida E83 probing system with optical transmission for CNC machining centers and milling machines boot... Read More
Boston Gear Publishes Coupling Guide January/9/2007
Boston Gear has published a comprehensive, 60-page reference guide to introduce its complete line of Huco couplings.
According to the... Read More Steinmeyer Introduces New Ball Bearings January/9/2007
Steinmeyer Inc. announced an addition to its standard line of miniature precision screws ? the "world's smallest commercially availab... Read More Makinos New Grinding Machining Center Grinds, Drills, Bores and Mills on the Same Machine January/9/2007
Makino introduced the G5 Grinder horizontal machining center, capable of grinding, drilling, boring and milling all on the same machine.
... Read More
Gleasons New Threaded Grinder Optimizes Fine Finishing of Hard Spur and Helical Gears January/2/2007
Gleasons new Genesis 130TWG High Speed Threaded Wheel Grinder features a new design that reduces floor space requirements and impro... Read More
Adcoles New Gage Features Spindle Refinements January/20/2006
A new, high accuracy vers... Read More
New Industrial Gear Oil Enhances Gearbox Durability January/15/2006
The new Mobilgear 600 XP Series of premium industrial gear oils was introdu... Read More
Midwest Motions New Control Features Built-In Reversing Switch and Speed Adjust Potentiometer January/15/2006
Read More
Mahr Federal Unveils Larger and More Flexible Measurement System January/6/2006
The new MarForm MMQ 400 Formtester from Mahr Federal is a ground-up redesign which is more robust, less sensitive to environmental influe... Read More
Schott Systeme Streamlines Gear Design Software April/15/2006
Schotte Systeme published a new video outlining how one single universal function has been designed to consolidate both 2D and 3D move... Read More
New Depressed Center Wheels Introduced by Camel Grinding Wheels April/6/2006
CGW-Camel Grinding Wheels has introduced Fast Cut Series Aluminum Oxide Type 27 Depressed Center Wheels with N-grade bond for right angle... Read More Philadelphia Gear Simplifies Controller April/7/2006
Philadelphia Gear Corp. introduces the Mark VII controller, which was developed for the companys Synchrotorque brand of variable sp... Read More New Multi-Axis Machining Software from NCCS April/6/2006
NCCS announces the new release of the latest version of NCL 9.5 that improves productivity by reducing both programming time and cycle ti... Read More Rockwell Automation Dodge Reliance Introduces New Helical/Bevel Speed Reducer April/6/2006
The new Dodge motorized Torque-Arm II (MTA) from Rockwell Automation is a high efficiency, case carburized helical/bevel speed reducer. T... Read More
Asahi America Introduces Plastic Gear Operator April/7/2006
Plasgear from Asahi America is a thermoplastic gear operator from Asahi America.
According to the companys press release, the P... Read More Magnetic Gearing and Turbine Corp. Releases New Injection Molded Plastic Gears April/6/2006
Magnetic Gearing & Turbine Corporation of Australia annonced the release of a new generation injection moulded magnetic gear.
Accordi... Read More New Vibration Mounts from AAC Feature Finger-Flex Ring and Bushing Isolators April/2/2006
The new V10Z 4 Series of vibration mounts from Advanced Antivibration Components feature unique "Finger-Flex" isolators which are designe... Read More Danaher Motion?s Planetary Gearheads Require No Maintenance April/1/2006
[photo]Danaher Motion's Micron ValueTRUE planetary gearheads are a more economical extension to Danaher Motion's family of Micron... Read More Rex-Cut?s Fiber Mounted Points Line Reveals Fresh Abrasives April/27/2006
New cotton-fiber mounted points from Rex-Cut Products expose fresh abrasives as they work to deburr and finish in one step with chatter-f... Read More Nitrex Develops New Small-Scale Furnaces April/14/2006
The new NX-400 series of nitriding and nitrocarburizing systems from Nitrex Metal is designed for use in small-scale processing, as well ... Read More Sterling Instrument?s New Precision Internal Gears Selectable by Inches or Millimeters April/30/2006
New precision internal gears from Sterling Instrument are available from stock in inch and metric sizes.
The 20? pressure angle inch ... Read More Allegro Releases Two New Motor Drivers April/18/2006
The A3992 is a complete microstepping motor driver with serial interface and outputs rated at ?1.5 A and 50 V. The A3992SB-T has the same... Read More
Bryan Grinder Releases New Software April/3/2006
Bryant? Grinder, a division of Vermont Machine Tool, released Revelations? software, a Microsoft Windows-based, CNC control software that... Read More Nireco America Introduces Geared Dancer Roll Potentiometer April/29/2006
Nireco America Corp. introduced the Series 2699 geared dancer roll potentiometer. The heavy duty, high precision geared potentiometer is ... Read More Accura Technics New Grinder Works on Multiple Surfaces April/22/2006
Accura Technics newest product is designed for precision grinding applicable to aerospace, automotive, bearing and optics manufactu... Read More
Stainless Steel Cut-off Wheels Feature Thin Profile April/22/2006
The Alpha Green cut-off wheels for stainless steel feature a thin profile that cuts faster than conventional thicker wheels and are avail... Read More New Gearmotor from Midwest Motion April/22/2006
Midwest Motion Products released the Model No. MMP-S28-400A GP81-046 BR-015 gear motor, which accepts any 24-volt DC source, including b... Read More
alpha gears Right Angle Gear Reducer Designed for High Reduction Ratios April/22/2006
alphas TPK+ dual technology gear reducer is a two-stage right-angle gearhead for servo applications featuring a robot flange accord... Read More Sumitomos New Inserts Feature Six Cutting Edges April/22/2006
Sumitomo Electrics new 55 degree SumiTurn T-REX triangle insert was launched as a replacement for the 55 degree DNMG. The T-REX fea... Read More
Walter Grinders New Tool Grinder Offers Shorter Cycle Times April/22/2006
Walter Grinders unveiled its Helitronic Vision CNC tool grinder at IMTS. According to the companys press release, the grinder offer... Read More
Advent Tool & Manufacturing Debuts New Involute Spline Milling Solution April/22/2006
Advent Tool & Manufacturing released its indexable form milling platform for involute splines, spur gears, "V" shaped gears, and various ... Read More Alpha Gear Releases New Gearhead April/22/2006
The TK+ from Alpha Gear is a low-backlash, right-angle gearhead with hypoid technology.
According to alpha gears literature, the... Read More Marposs Gages Go Wireless April/20/2006
Marposs Corp. introduced its M1 Wave wireless electronic bore gages at IMTS.
"Marposs has cut the cord," said product manager Bob Harm... Read More Mastercams Latest CNC Software Enhanced to Provide Multi-Axis Toolpaths April/20/2006
The new Maintenance Release 2 (MR2) software from Mastercam introduces new capabilities including multi-axis toolpaths and Mastercam X a... Read More
SKFs New Ball Bearings Reduce Noise in Air Handling Applications April/15/2006
SKF? ConCentra ball bearing units for high-speed air handling applications integrate unique concentric locking technology to form a near ... Read More
Two-Piece Balanced Gear Clamps From Sterling Feature Balanced Design April/5/2006
A new series of two-piece clamps for retaining gears on shafts, introduced by Sterling Instrument, provide easy installation when neither... Read More Rex-Cut Introduces Cut-Off Wheels for Stainless Steel April/15/2006
The ALPHA-GREEN Stainless Steel Cut-Off Wheels Type 1 and Type 27 cut-off wheels feature a thin profile which cuts faster than conventio... Read More Heidenhain Introduces New Linear Encoder April/15/2006
For straightforward motion applications where primarily simple and fast mounting of a small encoder is decisive, HEIDENHAIN now offers a ... Read More China Pneumatic Unveils Precision Planetary Gear Reducers April/14/2006
China Pneumatic Corp. is introducing a new line of precision planetary gear reducers for air motors, servo motors and stepping motors for... Read More SMW Autoblok Introduces New Line of Live Tooling April/14/2006
SMW Autoblok introduces a complete line of live tools to provide increased machine utilization of turning centers, resulting in more part... Read More Tornos Technologies Debuts New Swiss-Type Multi-Axis Machine April/14/2006
The new DECO 8sp single-spindle Swiss-type multi-axis, multi-function machine will be making its debut at IMTS.
The machine accommoda... Read More Beaumont Machine Introduces Two-Step Diffuser Process April/11/2006
Beaumont Machine plans to exhibit its two-step diffuser process at this years IMTS.
Diffuser shapes have become a challenge fo... Read More
Weilers New Brochure Details In-Machine CNC Deburring on Flat Surfaces April/11/2006
Weiler Corp.s newest brochure details its in-machine CNC deburring of flat surfaces and highlights the companys Nylox disc br... Read More
NUMs Graphical and Conversational Software Compatible with Gear Manufacturing April/11/2006
NUMs control systems will be displayed at IMTS and are suitable for use in gear manufacturing. The embedded machining cycles for ge... Read More
New Gearbox for Power Transmission Applications April/24/2006
SIPCO Mechanical Linkage Solution launched its newest addition to the Technogear? product line.
The new LC precision planetary series... Read More Zimmerman Presents New Milling Machine with Linear Drive April/14/2006
The new FZ 38 from Zimmerman is a CNC portal milling machine driven by linear motors.
According to the company's press release, the ... Read More Alpha Gear Launches Hypoid Gearhead April/19/2006
The new HG+ series from alpha gear drives Inc. is a low-backlash hypoid gearhead that offers performance similar to a planetary gearhead.... Read More
Cincinnati Machines New Five-Axis HMC Optimized for Titanium Machining April/19/2006
Cincinnati Machines new MEGA5-800 five-axis horizontal machining center utilizes the basic MEGA twin ball screw-driven axes configu... Read More
Schunk?s New Toolholder Designed for Low Interference Applications April/19/2006
The TRIBOS-RM from Schunk is designed for cutting speeds up to 50,000 rpm while offering run-out accuracy of less than three microns. The... Read More Midwest Motion Announces New DC Motor April/19/2006
Midwest Motion Products released the MMP-TM55-12V GP52-035 gearmotor that accepts any 12-volt DC source, including battery power.
Meas... Read More Rush Gears Introduces Gear Gages April/19/2006
Rush Gears is introducing a new line of gear gages with standard diametral pitch sets coming with 3, 4, 6, 8, 10, 12, 16, 20, 24, 32, and... Read More Marposs? New Gear Tester Detects Correct Tooth Hardness April/19/2006
The E59n from Marposs is a mechanical system where the gears are loaded and correctly referred before being tested. The integrated eddy c... Read More Junker?s High Speed Process Grinds Gear Shafts in One Clamping April/19/2006
The Quickpoint 3000 from Erwin Junker Machinery uses a CNC swivel grinding spindle headstock with three grinding spindles and several gri... Read More Nortons New Gear Grinding Wheels Increase Life of Parallel Axis Spur Gears April/11/2006
The new BRGg VPHS high speed grinding wheels from Saint Gobain are designed to reduce cycle times by increasing metal removal rates. The ... Read More SPV Spintec?s Automatic Deburring Machine Designed Especially for Gear Wheels April/27/2006
The new 68 2006 automatic deburring machine from SPV Spintec is designed for deburring of gear wheels, flanges and other circular symmetr... Read More LMS Revises Virtual Lab April/11/2006
LMS released Virtual Lab Rev 6, an advanced and unified modeling environment, integrating all the required model creation and simulation ... Read More
Kinefac Introduces New Automated Production System April/6/2006
Kinefac is introducing a new Robo-Roller, which is a quick changeover, automated production system for rolling threads, knurls, worms and... Read More
SKFs New Cylindrical Roller Bearings Extend Wind Turbine Gearbox Life April/11/2006
New SKF high-capacity cylindrical roller bearings for wind turbine gearboxes have been engineered to promote longer gearbox service life... Read More
SCHUNK Introduces New Workholding Technique April/11/2006
SCHUNK's new line of magnetic clamping technology can be optimally applied when used in conjunction with the company's quick-chan... Read More Drakes Newest Thread Grinder Utilizes Robot Load/Unload System April/11/2006
The GS: TE-LM thread grinder from Drake Manufacturing is fitted with a robot load/unload system that provides maximum throughput for high... Read More Boston Gear Publishes Gearhead Brochure April/8/2006
Boston Gear has published a full color,
36-page brochure to introduce a new high precision helical planetary gearheads
The gearheads ... Read More
Landis Introduces New Grinders at IMTS April/6/2006
Landis Grinding Systems new LT1-1200 flexible CNC grinder with variable swiveling wheelhead will be displayed for the first time at... Read More
Marposs Introduces Bluetooth Measurement Products April/2/2006
Marposs Corp. will introduce its Merlin gage computer-based embedded technology and M1 Wave electronic bore gage containing Bluetooth wir... Read More Parker Expands Its PowerStation Family April/8/2006
Parker Automaton-CTC introduced the EPX10S, which is equipped with a 10" TFT, SVGA display and
analog resistive touchscreen. It joins th... Read More Sandvik Introduces Next Generation of Insert Grades May/1/2006
The GC1030, GC4240 and GC4225 from Sandvik Coromant were designed to enhance productivity in steel milling operations.
The GC1030 and ... Read More
Royal Purple Develops High Performance Worm Gear Oils May/1/2006
Royal Purple developed a para-synthetic Synergy Worm Gear Oil and a fully synthetic Thermyl-Glyde Worm Gear Oil.
Both contain slippery... Read More Reishauer to Exhibit Hard Gear Finishing and Automation Technology at IMTS April/2/2006
Reishauer plans to exhibit the RZ 400 precision gear grinding machine at IMTS 2006. The machine incorporates new technology, including ge... Read More
Torque Transmission Introduces New Line of Right Angle Drives April/2/2006
Torque Transmission introduced a line of right angle gear drives designed for various motion control applications where right angle motio... Read More
NexxtDrives Variable Speed Power Take-Off Provides Micro Hybrid-Functionality April/2/2006
The NexxtPTO is a compact, variable speed mechanical power take-off that can be configured to act as an engine starter and alternator, pr... Read More
New Gearhead from Boston Gear May/1/2006
New gearheads from Boston Gear are designed for direct attachment to popular servo and stepper motors. These durable, long-lasting perfor... Read More Ondrives New Gearbox Emphasizes Torque and Speed April/11/2006
A new line of DC motorized worm and wheel reduction gearboxes from Ondrives is fitted with 24V DC motors that operate at 12V DC.
Accor... Read More
Marposs New Gage Head Designed for Internal Grinders April/11/2006
The Thruvar from Marposs is a through-the-spindle gage for in-process measurement application on internal grinding machines and was intro... Read More
DSMs Stanyl Precison Gears Help Disabled Patients Drive Independently April/11/2006
Precision gears made out of Stanyl, a high-performance polyamide 46 (PA46) resin from DSM Engineering Plastics, help keeps the Joyster mo... Read More
Alpha Gears Gearmotor Offers Significant Reduction in Inertia April/11/2006
The TPM from alpha gear drives Inc. is a geared motor containing a rotary actuator based on an AC servo motor and high precision planetar... Read More
Alpha Gear?s New Gearhead Follows Trends in High Reduction Torque and Ratios April/11/2006
The new SPK+ right-angle gearhead is designed for applications with high reduction ratios and torques.
This product combines features ... Read More New A-Track Series Linear Actuators April/15/2006
March 15, 2006 ? South Beloit, IL ? Warner Electric announces the availability of new A-Track Series Linear Actuators. The new series of... Read More Gleason Genesis S130SV Gear Shaving Machine April/8/2006
The 130SV shaving machine from Gleason is the newest of the companys Genesis family of gear production equipment.
Introduced to... Read More
Kapp Highlights Gear Center April/13/2006
The Kapp KX300P occupies only 65 square feet of floor space and uses either dressable or non-dressable worm and form wheels.
Additio... Read More Alpha Gear Introduces Economy Line of Gearheads April/12/2006
The LP+/LPB+ value line of gearheads from alpha gear Inc. offer efficiency with low torsional backlash for less demanding applications.
... Read More PCB Piezotronics New Rotary Torque Sensor System April/12/2006
The rotary torque sensor system from the Force/Torque Division of PCB Piezotronics is designed for automotive driveline and powertrain dy... Read More
Zero Maxs New Linear Actuators Convert Rotary Motion into Precise Linear Motion April/12/2006
The Rohlix linear actuators from Zero-Max convert rotary motion to linear travel and carry loads at speeds up to 70" per second, de... Read More Alpha Gear?s Newest Software Simplifies Selecting Gear Reducers April/12/2006
The Cymex calculation software from alpha gear drives Inc. uses a database of company products and 6,000 motors from various manufacturer... Read More Neeter Drive Gearboxes Transmit Power up to 6600 N-m April/12/2006
The PowerGear range of bevel gearboxes from Neeter Drives is available in sizes 360 and 450 with an extended transmission range of 3,750 ... Read More
Samputensili?s Master Gears Personalized to Customer/DIN Specifications April/12/2006
Samputensili has introduced a range of master gears to determine work gear accuracy and setting masters to adjust checking equipment.
... Read More Parker Bayside Combines Servo Motor and Helical Planetary Gearhead April/12/2006
The Stealth line of gearmotors from Parker Bayside represents the first time a brushless servo motor and a helical planetary gearhead hav... Read More
Midwest Motions Gearmotor Accepts Battery Power April/12/2006
The Model MMP-TM55-12V GP52-308 gearmotor from Midwest Motion accepts any 12-volt DC source including battery power and measures 2.14" in... Read More Bison Gear Introduces Line of AC Motors April/12/2006
Bison Gear & Engineering introduced a new line of custom AC motors manufactured in their St. Charles, IL, facility.
Motors will be ava... Read More Sterling Instruments Anti-Backlash Gears Eliminate Marred Shafts March/10/2006
A new series of 1158 anti-backlash gears manufactured by Sterling Instruments feature the Fairloc integral hub fastening system, which el... Read More
Mahrs Air Gage Uses Single- or Dual-Master Air Tooling March/10/2006
The Universal Dimensionair line of air gages from Mahr Federal combines the performance of a single-master air gage system with the abili... Read More
Marposs? Vertical Solution Provides a Smaller Footprint March/10/2006
The M57V bench from Marposs provides a smaller footprint that occupies less surface space than the company's horizontal solution, a... Read More Bison Gears Hollow Shaft Gearmotor Doubles Continuous Torque Ratings March/10/2006
Bison Gears new 562 series hollow shaft gearmotor offers increased low speed center distance coupled with greater clearance for wid... Read More
Allegro MicroSystems New Motor Driver Completes Product Family April/4/2006
Allegro MicroSystems announced a new DMOS full-bride motor driver to complement their parallel input DC motor driver family.
Designed... Read More
Gleason Introduces Newest Hobbing Machine February/15/2006
The new Genesis 130H CNC vertical hobbing machine features a design that optimizes dry machining, reduces floor space and improves cycle ... Read More
Boston Gear Introduces New Worm Gear Reducer January/10/2006
A new 700 Series Conveyor Flange Adapter (CFA) is specifically designed for increased control and lower maintenance cost on material hand... Read More Midwest Motion Gearmotor Accepts 12-Volt DC Sources January/19/2005
The Model No. MMP-TM55-12V GP52-022 DC gear motor from Midwest Motion can accept any 12-volt DC source, including battery power, says the... Read More Hexagon Metrology Debuts CNC Measuring Arm at Fabtech January/19/2005
Hexagon Metrology introduced a new CNC articulated measuring arm at Fabtech that president and CEO William Gruber calls ?our version of a... Read More Donner + Pfister Introduces New Measuring Equipment January/19/2005
The ES 4100 portable pitch measuring instrument from Donner + Pfister offers measuring data. Operational convenience is achieved by the b... Read More Saint-Gobain Gaskets Seal in Temperature Extremes January/19/2005
The OmniGasket from Saint-Gobain is constructed with a layer of PTFE adhered to an alloy base.According to the company's press releas... Read More Marposs Newest Software Enables On-Machine Measuring January/18/2006
The 3D Shape Inspector software for on-machine measurement application from Marposs is used with the companys touch probes and enab... Read More
Frenco Adds Gage for Measuring Splines to Produce A Circumferential Backlash Measuring Instrument April/16/2005
Frenco has expanded its product line by starting to produce a circumferential backlash measuring instrument.
According to its press r... Read More
New High-Speed Inspection System from Renishaw February/9/2005
Introduced at EMO, the Renscan5 high-speed inspection system from Renishaw delivers part inspection speeds up to 20 times faster than con... Read More New Clamping Devices for Tool and Hob Manufacturing from Toolink February/9/2005
The K?nigdorn hydraulic expansion mandrels from Toolink Enginering manually clamp hobs located between centers on the machine. The system... Read More New Superabrasive Turning Machine from Holroyd February/9/2005
The Edgetek SATurn Superabrasive turning system from Holroyd employs CBN wheels to achieve productivity rates far in advance of those obt... Read More
New Gear Deburring Brushes from Weiler February/9/2005
The Bore-RX line of internal gear deburring brushes from Weiler can increase productivity of in-machine deburring in CNC machining center... Read More
New Bore Finishing Machines from Engis February/9/2005
The six-spindle SPM Series single-pass bore finishing machine from Engis can finish the bores on as many as 480 gears per hour with tool ... Read More
New Gear Hobbing Center from Koepfer EMAG February/24/2005
The VSC 250/400 DUO WF from EMAG Koepfer allows complete soft machining of gears on a single machine.
According to the companys ... Read More
New Scanner from Induction Tooling February/20/2005
The Model No. Scan I.T-LRS36 scanner from Induction Tooling was introducted at Gear Expo 2005.
According to the companys literat... Read More New Vertical Processing Machine from Inductoheat February/11/2005
The modular Inductoscan vertical processing machine from Inductoheat is designed to ofer customers greater flexibility and higher uptime.... Read More
New Series of Bevel Gear Operators from Flowserve January/6/2005
The Limitorque Actuation System MT Series of bevel gear opeators from Flowserve are optimized to perform in power industry valve applicat... Read More
New Sulfide Material from Ticona Makes Braking Easier January/4/2005
Fortron linear polyphenylene sulfide (PPS) for actuator housings and gears to help transfer power from the actuator motor to the brakes.
... Read More
Harmonic Drive Introduces New Gearheads January/3/2005
Harmonic Drive Technologies introduced its RGH Series of compact gearheads that offer the accuracy and repeatability typically associated... Read More
New Dispenser from Kluber Allows for More Accurate Dispensing January/3/2005
The Klubermatic FG lubricant dispenser allows for hygienic and accurate dispensing of lubricating grease to machinery in the food and pha... Read More
Samputensil Introduces High Capacity Grinding Machine January/6/2006
The new 250G generating grinding machine from Samputensili, introduced at EMO 2005 was developed to achieve a shorter cycle time.
Acco... Read More New Brake for Gearless Drives February/3/2006
Ortlinghaus has introduced the DIMO braking system for gearless applications.
The brake is electromagnetically actuated. According to... Read More
New Abrasive Nylon Disc Brushes from Weiler Specialize in In-Machine Deburring April/19/2006
The Burr-Rx line of abrasive nylon disc brushes from Weiler Corp. are specially designed for in-machine deburring applications.
The br... Read More
New Gear Hardening Technology from Inductoheat April/3/2005
Inductoheat has introduced Simultaneous Dual Frequency (SDF)induction gear heating process.
According to the companys press rele... Read More
United Grinding?s Newest Machine Grinds Shafts and Chucked Workpieces April/11/2006
[photo] The Studen S242 from United Grinding is designed for the hard turning and grinding of high-precision applications for both shaf... Read More New Gearmotor from Midwest Motion February/3/2005
The new MMP-TM55-36V-007 DC gear motor from Midwest Motion Products can accept any 36-volt DC source, including batteries.
New Gear Lubricant from Kl?ber February/18/2005
The Kl?bertop P 39-462 spray from Kl?ber Lubrication facilitates the adjustment of load-bearing patterns in gears and is resistant to syn... Read More New Mandrels from LeCount February/14/2005
The new Type G mandrel from LeCount is designed to accomodate most between-center grind operations.
A PartLocator is an optional enhan... Read More
New Process Monitoring System from Marposs April/13/2005
A new tool and process monitoring system from Marposs is designed to provide continuous monitoring of metalworking processes through seve... Read More New Chamfer/Deburring Machines from Star SU April/18/2005
The S250CD, S250CDA and S250CDX chamfer/deburring machines from Star SU replace the older SCT and SM series in the U.S. market. The new C... Read More New Frequency Inverter from SEW Eurodrive April/21/2005
The Movitrac Lte frequency inverter is a system design to meet the size and startup constraints that industrial applications often place ... Read More New Vertical Scanning Machine from Inductoheat April/21/2005
The new modular Statiscan vertical scanning machine from Inductoheat is tooled up to process steering input shafts.
New Power Transmission Package from Brevini April/14/2005
The new High Power Series from Brevini combines the gear design of the S Series planetary gearboxes with modular features of the PIV POSI... Read More
Lin Engineering Introduces New Motors April/13/2005
Lin Engineering Inc. has introduced a new line of IP65-rated motors. These motors are available in size 17 and 23 and offer protection a... Read More Flowserve Introduces New Models to PT Series Worm Gears April/13/2005
Flowserve Corp., a provider of fluid motion and control products and services, added two new sizes to the Flowserve Limitorque PT series ... Read More New Planetary Gear Unit from Gudel April/15/2005
The new planetary gear unit from Gudel supplies solutions for power trains requiring high dynamics.
The power train and integrated pi... Read More
Bock Workholding Introduces New Triangular Workholding System for Machining Centers April/13/2005
The Bock TriSystem workholding system, a triangular, six-station workholding system allows a greater range of tool access angles on horiz... Read More
KTR Introduces New Couplings April/16/2005
The Rotex ZS-DKM-H from KTR Corp. has been developed for the pump industry. The main innovation feature of the H type coupling is the she... Read More
HSI Introduces New Linear Actuator April/13/2005
The Size 8 captive linear actuator from Hayden Switch & Instrument includes actuator options that open avenues for equipment designers wh... Read More IMPCO Machine Tools Introduces New Laser Checking System April/12/2005
The new OPTI-Scan Class II CE-certified laser heads from IMPCO Machine Tools are designed to perform final inspection of precisely machin... Read More
Voith Introduces New Fluid Coupling April/13/2005
The new TurboSyn friction coupling from Voith Turbo increases the economy of single drives and utilizes its potential for energy savings.... Read More HSI Introduces New Linear Actuator April/13/2005
[photo] The Size 8 captive linear actuator from Hayden Switch & Instrument includes actuator options that open avenues for equipment desi... Read More SEW-Eurodrive Introduces New Food Industry Drive System April/29/2005
The Food Industry Option Package from SEW-Eurodrive is a drive system with specialized components to meet the damp conditions and chemica... Read More NSK Introduces New Bearings April/13/2005
[photo] NSK's new BGR Series of super precision angular contact bearings combines the benefits of SHX heat and seizure resistant stee... Read More New Gear Drive System from ASI Technologies April/12/2005
The MK400 Series transaxle from ASI Technologies combines the precision of a single piece casting, which can improve the accuracy of gear... Read More
New U-Shaped Gearmotors from Bodine April/12/2005
The new type HG gearhead from Bodine provides flexible mounting and high torque for applications including conveyor systems, food process... Read More
Falk Creates New Right Angle Gearmotor April/13/2005
A new line of stainless steel helical bevel gear drives from Falk is recommended for food industry sanitation requirements. These drives ... Read More Aerotech Introduces New Gantry System April/13/2005
The ASGS1000 Series Cartesian gantry system from Aerotech is designed for a range of automation platforms like high-speed pick-and-place,... Read More
New Brochure from Weiler Corp. April/4/2005
The latest brochure from Weiler Corp. details the importance of deburring in gear manufacturing.
All cutting and shaping operations p... Read More
Cotta Transmission Introduces New Creep Drive Gearbox April/8/2005
Cotta's new creep drive transmission is designed to insert in the vehicle driveline after the main transmission. In the creep mode, t... Read More New Gearmotors from Bison Gear March/18/2005
The new parallel shaft AC gearmotors from Bison Gear & Engineering are available in five gear ratios ranging from 5.8:1 to 42.8:1.
Th... Read More First 7-Speed Gearbox has a Shift Plate of DuPont Zytel March/26/2005
A shift plate made of DuPont Zytel nylon carries the fully integrated gear change control system of DaimlerChryslers 7G-Tronic seve... Read More New Furnace from Grieve March/9/2005
The No. 943 pit furnace from Grieve is an electrically heated, top loading pit furnace capable of 2,000 degrees F and is suitable for hea... Read More
New Face Drivers for Gear Hobbing from Logansport February/2/2005
The FDNC face drivers from Logansport Matsumoto are designed for gear hobbing operations.
According to the companys press releas... Read More
New Size 17 Gearhead from HD Systems February/2/2005
The Quantum Series from HD Systems is the highest torque capacity harmonic gearhead that the company has ever produced.
According to H... Read More American Stress Technologies Introduces New Inspection System February/15/2005
For the gear manufacturer plagued with nightmares about the possibility of grinding damage, GearScan 600 from American Stress Technologie... Read More
New Oil from Heatbath Corp. February/2/2005
Lab Oil 100 from Heatbath Corp. is dry-to-the-touch over phosphate coating, low in toxicity, has improved emulsification and high corrosi... Read More Midwest Motion Releases 24-Volt Gearmotor January/28/2005
A new, compact gear motor that accepts any 24 VDC power source has been released by Midwest Motion Products. Model MMP.C21.230B-24V.GP52-... Read More New Lead Angle Gear Roller from Marposs January/28/2005
The M62 DF from Marposs is designed for the dynamic inspection of ring gears with automatic part rotation.
The system can also evalua... Read More
