Necessity as the Mother of Invention October 2, 2018 Charles D. Schultz No Comments When you offer rebuilding service...Read More
Acceptable Fixes September 27, 2018 Charles D. Schultz No Comments You do not always have to say “no” when confronted with non-conforming parts. Here are a few “fixes” I have been comfortable authorizing: Read More
Norton | Saint-Gobain Increases Grinding Productivity with Winter Vitrified CBN Wheels September 21, 2018 Saint-Gobain Abrasives has announced the introduction of its new Norton Winter Vitron7 cBN Grinding Wheels. The wheels feature a high-p...Read More
Adjust Tolerances or Expectations? September 19, 2018 Charles D. Schultz No Comments There is a great deal of science involved in measuring things, but considerably less on what the baseline dimensions and clearances should be. This...Read More
Grinding Machines Increase Quality and Productivity at Nixon Gear September 18, 2018 Two new grinding machines were recently added to production at Gear Motions’ Nixon Gear Division in Syracuse, NY.The Studer S121 is...Read More
The Usual Suspects September 14, 2018 Charles D. Schultz No Comments Once you accept that “stuff” happens in even the best of machine shops, you can begin to assess where the problems are likely to occur and start th...Read More
Something is not Right Here September 7, 2018 Charles D. Schultz No Comments Another benefi...Read More
Hainbuch Taps Hänel for Mandrel Prototype Test September 5, 2018 Matthew Jaster No Comments Hard work and first-class teamwork between the gear factory Hänel and Hainbuch has paid off. The new mandrel Mando G211 for gear manufacturers, sui...Read More
Gearbox Design: Let the Fun Begin September 4, 2018 Charles D. Schultz No Comments It is perfectl...Read More
Influence of Different Manufacturing Processes on Properties of Surface-Densified PM Gears September 1, 2018 The properties of both shot-peened and cold rolled PM gears are analyzed and compared. To quantify the effect of both manufacturing processes, the tooth root bending fatigue strength will be evaluated and compared to wrought gears.Read More
