At AMB 2022, WFL Millturn Technologies will be presenting the new M20 MILLTURN complete machining center for the first time. Alongside gear skiving technology, there is clear trend toward automation and the integration of sensors. The latest solutions from WFL range from smart software to screw programming through to intelligent tools and clamping devices.
Forming tools are expensive, often made from carbide and tool steel. Carbide grinding is often the first choice today because customer requirements have increased and continue to increase in terms of complexity, dimensional accuracy and reproducibility. Apart from that, production must also be significantly more economical.
System-supplier Klingelnberg will be back at AMB (Booth C41, Hall 5), where it will be highlighting solutions for smooth-running gearboxes. The exhibit will feature the Höfler Cylindrical Gear Grinding Machine Speed Viper, the Klingelnberg Precision Measuring Center P 40 and the newly developed Höfler Cylindrical Gear Roll Testing Machine R 300.
Sandvik Coromant, has earned the 2022 IndustryWeek Best Plants Award for its Westminster, South Carolina, production site. The award is given to North American manufacturing plants that lead their industries in outstanding operational excellence, customer service and employee engagement.
Global EDM supplier also moves to new location to enhance production and service capabilities
August 16, 2022
Beaumont Machine is a builder of Electrical Discharge Machines (EDM) for the aerospace, power gen and electronics production industries. Founded by Ed and Tanya Beaumont over 30 years ago, the company was recently repurchased, after the owners had sold the business in early 2013.
IMTS visitors can experience live machining with the WFL M50 MILLTURN/3000 mm. The multifunctional turning-boring-milling center is designed for complete machining of complex chuck and shaft parts up to 670 mm swing over bed. Turning, milling, drilling, hobbing, shaping, gun drilling as well as ID machining can be performed under any angle of the tool.
When it comes to an early identification of noise problems in the drivetrain one has to take data analytics and its integration in the manufacturing process into account. The big vision here, in particular, is preventive quality. By evaluating sensor data of the machining process, it promises to predict whether a gear is ok or not ok.
EMAG will highlight productive, and at the same time, flexible manufacturing solutions for
electromobility at IMTS. Among other things, the focus is
on the vertical pick-up lathes of the VL series, which EMAG now delivers
IoT-Ready.
GROB Systems has announced a new YouTube Video Series called “Machine Minutes with GROB.” New technical tutorial and informational videos will be released regularly and will focus on three primary topics including Machine Design/ Building, Machine Applications, and Machine Maintenance and Inspection. The videos will generally range from two to eight minutes in length.
The variable machining of turned parts has never been easier. This is made possible with Duro-M, the new geared scroll chuck, innovative lens geometry and optimized power transmission by Röhm.
