A fundamental characteristic of the gear industry is that it is capital intensive. In the last decade, the gear manufacturing industry has been undergoing an intense drive toward improving and modernizing its capital equipment base. The Department of Commerce reports that annual sales of gear cutting equipment have increased nearly 60% since 1990. While this effort has paid off in increased competitiveness for the American gear industry, it is important to remember that there is another capital crucial to manufacturing success - "human capital."
What Is Whisker-Reinforced Ceramic?
Whisker-reinforced ceramic as applied to cutting tool inserts comprises a matrix of aluminum oxide into which approximately 50% by volume of high-purity silicon carbide "whiskers" are randomly dispersed. The "whiskers" are, in fact, single crystals having dimensions of approximately 0.6 microns in diameter x 10-80 microns in length. These "whiskers" have a tensile strength on the order of 1,000,000 psi (690 MPa). The composite material that is the best known and most widely applied using this technology is designated WG-300 and manufactured by the Greenleaf Corporation of Saegertown, PA.
The passage last year of both NAFTA and GATT has gone a long way toward leveling the playing field for American manufacturers and other hoping to compete in the global economy. Add to this news the fact that the domestic economy keeps growing, and it seems as though good times are ahead for the gear industry.
If someone were to tell you that he had a gear material that was stronger per pound than aluminum, as wear-resistant as steel, easier to machine than free-machining steel and capable of producing gears domestically for 20% less than those now cut from foreign made forgings, would you consider that material to be "high tech"? Probably. Well, throw out all the pre-conceived notions that you may have had about "high tech" materials. The high-performance material they didn't teach you about in school is austempered ductile iron (ADI).
