What Is Whisker-Reinforced Ceramic?
Whisker-reinforced ceramic as applied to cutting tool inserts comprises a matrix of aluminum oxide into which approximately 50% by volume of high-purity silicon carbide "whiskers" are randomly dispersed. The "whiskers" are, in fact, single crystals having dimensions of approximately 0.6 microns in diameter x 10-80 microns in length. These "whiskers" have a tensile strength on the order of 1,000,000 psi (690 MPa). The composite material that is the best known and most widely applied using this technology is designated WG-300 and manufactured by the Greenleaf Corporation of Saegertown, PA.
This issue's editorial is a reprint of the keynote address given by Michael Goldstein at the Computer Aided Gear Design Seminar held at the University of Northern Iowa, Cedar Falls, IA on November 9, 1987.
At the present time, technology seems to be moving faster than our ability to educate people in its utilization. this is particularly true of the manufacturing engineering profession.
