Companies around the world are learning to embrace the environment, and the gear industry is no exception. This special section takes a look at how some gear manufacturers are doing
their part to conserve resources, preserve and protect the environment, and give back to the land. What we’ve found is that adopting environmental
measures is far more than just good
corporate citizenship. For many gear industry companies, good environmental practices also turn out to be good for the bottom line.
For a high-speed gearbox, an important part of power losses is due to the mesh. A global estimation is not possible and an analytical approach is necessary with evaluations of three different origins of power losses: friction in mesh contact, gear windage and pumping effect between teeth.
This article was originally published 20 years ago, in Gear Technology’s first issue. It describes a method of
evaluating the smoothness, or lack of smoothness, of gear motion. This lack of smoothness of motion, known as
“transmission error,” is responsible for excitation of gear noise and problems of gear accuracy and sometimes has a relationship to gear failure.
