Top Secret
Code Name: Ginger
Mission: Design, prototype and test a transmission for a new device. The transmission must be compact and efficient. It should have almost no backlash, and it must be able to operate in both forward and reverse. Most importantly, the transmission must be quiet. In fact, it shouldn't sound like a transmission at all. It should blend in with the environment and sound like music or the wind. This mission, should you choose to accept it, is top secret. Not even your employees can know what you're working on...
Combining involute curves and body curves, merging factory and fashion, Winzeler Gear has transformed one of its products into gear haute couture. Winzeler Gear has created a plastic gear dress.
The performance of metal surfaces can be dramatically enhanced by the thermal process of rapid surface melting and re-solidification (RMRS). When the surface of a metal part (for instance, a gear) is melted and re-solidified in less than one thousandth of a second, the resulting changes in the material can lead to:
Increased wear and corrosion resistance,
Improved surface finish and appearance,
Enhanced surface uniformity and purity, and
Sealing of surface cracks and pores.
You go, and if your name is Ryan Boxx, you go faster than everyone else. Boxx became the fastest 15-year-old in America this summer when he won his division of the National Hot Rod Association's Junior Drag Racing League National Championship.
Come with us now to those thrilling days of yesteryear...Ok, this is not the Cisco Kid, but we do have a little game for you. Guess the year the following advertisements and excerpt were printed - they all appeared in a dingle issue of Machinery Magazine.
