Sumitomo WDX Series Drill Line Adds Coolant Through Models September 30, 2016 Sumitomo Electric Carbide, Inc.'s WDX Series large diameter drill line now includes WDX-L coolant through models.Reducing the cost pe...Read More
Nye Lubricants Develops Rheolube 460 Series September 27, 2016 Nye Lubricants is developing the next generation of synthetic hydrocarbon greases thickened with lithium soap. These new greases are the ...Read More
Mahr Offers Handheld Inspection Tool September 22, 2016 Mahr introduced the MarSurf PS 10 during IMTS in Chicago. The PS 10 brings smartphone operation and laboratory performance to the shop fl...Read More
Holroyd Tool Management Center Improves Accuracy and Repeatability of Milling Large Helical Rotors September 19, 2016 A newly developed ‘large diameter' CNC cutter grinding machine from Holroyd Precision Ltd is designed to bring considerable adv...Read More
Seco 150.10-JETI System Optimizes Coolant Delivery September 15, 2016 Designed to achieve increased productivity, tool life and part quality, the new Seco 150.10-JETI system significantly improves the heat r...Read More
IMTS 2016: Zoller Inc. (W-2022) September 9, 2016 »hobCheck« Gear Hob Measuring MachineThe Zoller »hobCheck« brings an expanded range of possibilities and solution...Read More
IMTS 2016: Vargus USA (W-2446) September 9, 2016 Gear Milling SystemAt IMTS 2016, Vargus USA will launch a standard line of indexable and solid carbide gear milling tools for a wide rang...Read More
IMTS 2016: Solar Manufacturing (N-6358) September 9, 2016 Solar Manufacturing will be introducing a new, innovative and more thermally efficient hot zone design at IMTS 2016 in Chicago for the be...Read More
IMTS 2016: Speedgrip Chuck (W-2222) September 9, 2016 Quick Change Adapter SystemSpeedgrip will be showing their new Quick Change Adapter System at IMTS 2016. Merging the tested and true Caml...Read More
IMTS 2016: Oerlikon Balzers (W-2380) September 9, 2016 Balinit AltensaThe Balinit Altensa is the newest product in the successful AlCrN family and it stands out especially through its wear res...Read More
