Houghton International HOCUT 4650 Heavy Duty Bi-Metal Honing Fluid Meets All Global Chemical Regulations April 27, 2016 Houghton International has launched a new water-based metal removal fluid for use in automotive honing operations. HOCUT 4650 improves ma...Read More
Hannover Messe 2016 Preview: KISSsoft April 22, 2016 On April 25, Hannover Messe opens its doors. At the same time, the new version of KISSsoft 03/2016 will be released with a number of...Read More
Kluber Lubrication Gluberlub and Kluberplex Solutions Designed for Offshore Industry April 21, 2016 Klϋber Lubrication will feature its multi-purpose oils and greases for offshore applications at booth #2923 during the Offshore Tech...Read More
Dillon Manufacturing Reversible Hard Jaws Suitable for Both ID and OD Workholding April 20, 2016 Reversible hard jaws from Dillon Manufacturing, Inc., which are suitable for ID and OD workholding, can decrease the time and cost of too...Read More
Ransohoff WasteWizard Features Siemens Controls and Expandable Modules April 19, 2016 Ransohoff has introduced the next generation of its WasteWizard solution recycling system, which now features advanced Siemens controls w...Read More
Walter Titex DB133 Supreme Micro Drill Designed with New Geometry, Uniform Finish April 18, 2016 Walter has introduced the Walter Titex DB133 Supreme, a solid carbide micro drill that is designed to deliver tight tolerances, high qual...Read More
Holroyd Precision Limited Zenith 400 Helical Profile Grinder Works with Aluminum Oxide, CBN and Vitrified CBN Technologies April 15, 2016 Precision Technologies Group company, Holroyd Precision Limited, is to supply one of its ultra-precise Zenith 400 helical profile grinder...Read More
Fixtureworks One-Touch Manual Clamps Designed to Eliminate Need for Tools for Applying Clamping Force April 14, 2016 Fixtureworks is now offering an extensive new lineup of One-Touch manual clamps. One-Touch clamps offer easy and efficient clampi...Read More
Traub TNL32-11 11-Axis Automatic Lathe Reduces Downtime, Negates Acceleration Time April 13, 2016 The new Traub TNL32-11 sliding/fixed headstock automatic lathe has a headstock moving in the Z-axis, an upper and identical lower turret ...Read More
Ransohoff TT-180 Ransobotic Washer Specialized to Wash Complex and Large Parts Fast April 12, 2016 Ransohoff has introduced its TT-180 Ransobotic Washer, a robotic parts washing unit that brings more speed, precision and efficiency to p...Read More
