Jenoptik Automotive Offers Hommel-Etamic AG380 Pneumatic Snap Gage October 27, 2016 Jenoptik Automotive recently introduced the Hommel-Etamic AG380 pneumatic snap gage to quickly, cost-effectively and flexibly check a ran...Read More
Ajax TOCCO Magnethermic Bright Annealing Induction Furnace Produces Ready-to-Ship Finish October 26, 2016 Ajax TOCCO Magnethermic recently shipped a bright annealing induction furnace to a major stainless steel tube manufacturer in the Northea...Read More
Traub TNL18 Series Automatic Lathe Line Adds New Lathes and Drive Train October 25, 2016 The Traub TNL18 series Swiss-style automatic lathes perform more dynamically with an enhanced CNC control, axis amplifier, and more dynam...Read More
Kwik Mark Tag Master 3 Dot Peen Marking System Feeds Tags from Top October 24, 2016 The new Tag Master 3 feeder was developed to eliminate the problematic tag feeding issues of escaping tags from the bottom of the magazin...Read More
Kennametal Mill 4-11 Indexable Shoulder Mill Designed for Smooth Cuts with Small Machining Centers October 21, 2016 Two years ago, Kennametal introduced a double-sided 90 degrees milling platform that eliminates this issue while providing manufacturers ...Read More
Walter MC341 Supreme Carbide Milling Cutter Designed for Machining Steel and Stainless Steel October 20, 2016 The new MC341 Supreme carbide shoulder/slot milling cutter from Walter is specially designed for extended tool life when machining steel ...Read More
Mahr Federal Multimar 36 B Indicator Gage Expands Range of Accepted Contacts and Anvils October 19, 2016 Mahr Federal's Multimar 36 B Indicator Gage has been enhanced to accept a wider range of contacts and anvils, enabling measurement of...Read More
KISSsoft Determines Misalignment of Bevel Gears in Latest Update October 18, 2016 The relative position of the pinion and the ring gear is critical in determining the wear patterns of bevel gears. To determine the bevel...Read More
Sandvik Coromant Introduces Grade for ISO H05 and H15 Applications October 7, 2016 To help manufacturers enjoy benefits such as reduced cycle times and greater tool life when performing hard part turning, Sandvik Coroman...Read More
Okuma Genos L3000-M One-Saddle Lathe Designed for Cutting Exotic Materials October 6, 2016 Okuma's new Genos L3000-M one-saddle lathe is stronger, faster and ideal for cutting a wide range of exotic materials with ease. The ...Read More
