Walter Wear-Optimization App Decreases Wear on Indexable-Inserts and Round-Tools May 10, 2016 A new Walter app, which works on all current mobile devices and operating systems, enables users to identify all specific forms of wear o...Read More
Bourn & Koch Legacy Machine Tools Can be Remanufactured, Retrofitted or Repaired May 9, 2016 Over the last four decades, through numerous acquisitions Bourn & Koch, Inc. has become the Original Equipment Manufacturer (OEM) for...Read More
EasyZero Runout Compensation Nuts Feature Six Adjustment Screws for Fixing Runout Errors May 6, 2016 EasyZero runout compensation nuts quickly correct runout errors and misalignment for all round tools using ER collets, and will be featur...Read More
Holroyd EX Rotor Milling Machines Rough Mill and Finish Machine Stainless Steel Rotors May 4, 2016 A little over two years after building one of the world's largest rotor milling machines - an EX Series ‘8EX' model - for a...Read More
R&P Metrology Installs Large Mobile Inspection Equipment May 3, 2016 R&P Metrology GmbH has announced it has recently installed two very large portable measuring machines, one in Asia and one in Europe....Read More
Ricardo Software Ignite Vehicle System Simulator Incorporates Modelon's Optimica Compiler Toolkit May 3, 2016 Ricardo Software recently announced a key partnership that will deliver immediate benefits to users of its Ignite complete vehicle system...Read More
Fives Machining Systems Diagnostic Communication System Added to Cincinnati and Giddings & Lewis Machine Tools May 2, 2016 Fives Machining Systems is introducing a new remote diagnostics capability that allows machine operators to connect with Fives Cinci...Read More
GMTA SynchroFine 205 HS Gear Honing Machine Designed to Optimize Gear Finishing April 29, 2016 Now available from German Machine Tools of America (GMTA), the Präwema SynchroFine 205 HS gear honing machine features direct-driven...Read More
Niagara Cutter Niagara SN End Mills Feature Defined Radius, Three Sizes April 28, 2016 Niagara Cutter has expanded its range of end mills for high feed milling applications. The new Niagara SN 200R/400R/500R solid-carbide en...Read More
