Sandvik Coromant CoroTurn 300 Provides Cutting Edge in Sandvik's Technology March 28, 2016 For longitudinal and face turning, Sandvik Coromant has introduced the new CoroTurn 300 for higher component quality, increased handling ...Read More
KISSsoft Offers Strength Analysis for Cylindrical Gears March 24, 2016 The strength calculation method specified in Lloyd's Register:2013 has now been implemented. This specific standard for ships is now ...Read More
Suhner Rego-Fix reCool Directly Applies Coolant-Lubricant Mix to Cutting Edge, Improves Tool Life March 23, 2016 Rego-Fix has launched a cost-effective and efficient attachment for the application of coolant-lubrication liquids through a tool based o...Read More
Gleason Offers 500CB Cutter Build Inspection Machine March 21, 2016 Gleason Corporation has introduced its latest innovation, the 500CB Cutter Build Inspection Machine. The 500CB delivers more accura...Read More
Sumitomo DFC Double-Side 90° Milling Cutter Offers High Wear Resistance, Precision and Efficiency March 18, 2016 New from Sumitomo Electric Carbide Inc., the DFC Double-Sided 90º Milling Cutter is engineered for exceptional precision and efficie...Read More
Briney Tooling Systems Custom Dual Contact CAT50 Eliminates Customer's Need to Replace Catalogue of Lathes March 17, 2016 Recently, Briney Tooling Systems worked closely with a manufacturer to develop a custom Dual Contact CAT50 stick turning toolholder for a...Read More
Dürr Ecoclean EcoCDuty Cleaning System Built to Process Large Loads March 15, 2016 Dürr Ecoclean has developed a solvent-based cleaning system, the large-chamber EcoCDuty, for heat-treating contractors, metalforming...Read More
Mitutoyo Releases Renewed IP67 Coolant-Proof Calipers March 14, 2016 Mitutoyo America Corporation recently announced the renewal of the 500 Series IP67 Absolute Digimatic coolant-proof calipers. This produc...Read More
GMTA Offers Rasoma Machine Tools in North America March 11, 2016 German Machine Tools of America (GMTA) now offers a full line of Rasoma machining centers, including vertical turning centers, four-axis ...Read More
Seco Taper-Face Toolholders Provide Two Surfaces of Contact March 9, 2016 Seco has added a new range of taper-face toolholders to meet machinists' increasing needs for higher production and process reliabili...Read More
