NUMs Graphical and Conversational Software Compatible with Gear Manufacturing April 11, 2006 NUMs control systems will be displayed at IMTS and are suitable for use in gear manufacturing. The embedded machining cycles for ge...Read More
Nortons New Gear Grinding Wheels Increase Life of Parallel Axis Spur Gears April 11, 2006 The new BRGg VPHS high speed grinding wheels from Saint Gobain are designed to reduce cycle times by increasing metal removal rates. The ...Read More
LMS Revises Virtual Lab April 11, 2006 LMS released Virtual Lab Rev 6, an advanced and unified modeling environment, integrating all the required model creation and simulation ...Read More
Drakes Newest Thread Grinder Utilizes Robot Load/Unload System April 11, 2006 The GS: TE-LM thread grinder from Drake Manufacturing is fitted with a robot load/unload system that provides maximum throughput for high...Read More
SCHUNK Introduces New Workholding Technique April 11, 2006 SCHUNK's new line of magnetic clamping technology can be optimally applied when used in conjunction with the company's quick-chan...Read More
SKFs New Cylindrical Roller Bearings Extend Wind Turbine Gearbox Life April 11, 2006 New SKF high-capacity cylindrical roller bearings for wind turbine gearboxes have been engineered to promote longer gearbox service life...Read More
Ondrives New Gearbox Emphasizes Torque and Speed April 11, 2006 A new line of DC motorized worm and wheel reduction gearboxes from Ondrives is fitted with 24V DC motors that operate at 12V DC. Accor...Read More
Alpha Gear New Gearhead Follows Trends in High Reduction Torque and Ratios April 11, 2006 The new SPK+ right-angle gearhead is designed for applications with high reduction ratios and torques. This product combines features of...Read More
Alpha Gears Gearmotor Offers Significant Reduction in Inertia April 11, 2006 The TPM from alpha gear drives Inc. is a geared motor containing a rotary actuator based on an AC servo motor and high precision planetar...Read More
DSMs Stanyl Precison Gears Help Disabled Patients Drive Independently April 11, 2006 Precision gears made out of Stanyl, a high-performance polyamide 46 (PA46) resin from DSM Engineering Plastics, help keeps the Joyster mo...Read More
