Home » Understanding Fluid Flow to Improve Lubrication Efficiency
January 1, 2004
Excess lubricant supply in gearing contributes to power loss due to churning as well as the requirements of the lubrication system itself. Normally, a much larger amount of oil than required is used for cooling because so much of it is thrown away by centrifugal force. To lower the amount of lubricant required and
reduce those losses, it is necessary to discover the ideal location of the supplying nozzle.
