Home » A Model of the Pumping Action Between the Teeth of High-Speed Spur and Helical Gears
May 1, 2004
For a high-speed gearbox, an important part of power losses is due to the mesh. A global estimation is not possible and an analytical approach is necessary with evaluations of three different origins of power losses: friction in mesh contact, gear windage and pumping effect between teeth.
