Thanks to our many hardworking volunteer committee members, 2022 was a productive year for the AGMA Technical Division with the publication of two new and three revised information sheets. The AGMA Metallurgy & Materials committee finally published their long awaited revision of AGMA 923-C22, Metallurgical Specifications for Steel and Cast Iron Gearing, which defines metallurgical acceptance criteria for three quality grades used in multiple other AGMA standards. AGMA 925-B22, Effect of Tribology and Lubrication on Gear Surface Distress, published by the AGMA Helical Gear Rating committee, took seven years to publish and has more than double the content from the previous edition. The AGMA Bevel Gearing committee followed with their revised AGMA 929-C22, Calculation of Bevel Gear Top Land and Guidance on Cutter Edge Radius, which has expanded calculations to anywhere along the face width instead of just the toe, mean, and heel. The AGMA Gear Accuracy committee finally closed the book on their long awaited the new document, AGMA 943-A22, Tolerances for Spur and Helical Racks, which fills a gap in the AGMA catalog, being the first document to cover spur and helical rack tolerancing since the withdrawal of AGMA 390.03a in 1999. And last, but certainly not least, AGMA 955-A22, Guidance for Industrial Gear Lubrication, published by AGMA Lubrication committee, was created as the first step of separating ANSI/AGMA 9005-F16 into two documents addressing “lubricants” and “lubrication.”
Looking ahead to 2023, many AGMA technical committees plan to meet face to face for the first time since 2019, and they will continue work on ten projects.
The current list of active AGMA projects is:
AGMA technical committees are also the vehicle through which U.S. companies can be involved in international ISO gear standards.
ISO published five new documents in 2022:
ISO working groups also recently began meeting face to face again, which should speed up their document development.
In 2023 ISO working groups will continue work on the following twelve documents:
The expert knowledge, meticulous attention to detail, and consensus-building skills of our volunteer members who work hard to develop the standards often go unnoticed in the background. The benefits of their work, however, are front and center to the gear industry and gear users every day. For all the valuable contributions of our committee members to help, the gear industry, and gear users everywhere, we thank you!
