should be considered.
stress will be discussed.
One of the initiatives now in progress since the close of the American Gear Manufacturers Association (AGMA) 2014 Fall FTM was building a detailed timeline of the organization’s history since its founding in 1916.
This article presents a new spur gear 20-degree design that works interchangeably with the standard 20-degree system and achieves increased tooth bending strength and hence load carrying capacity.
