When you to to IMTS, you expect to see hoopla. The mass of machines and bodies gathered in one place should create an unmistakable level of energy and enthusiasm. IMTS 2000 seemed uncharacteristically quiet...
When you have a multi-million-dollar transfer line sitting on the shop floor waiting for gears that might take up to two months to get, you have a costly bottleneck.
