Dear Editor:
The load carrying behavior of gears is strongly influenced by local stress concentrations in the tooth root and by Hertzian pressure peaks in the tooth flanks produced by geometric deviations associated with manufacturing, assembly and deformation processes. The dynamic effects within the mesh are essentially determined by the engagement shock, the parametric excitation and also by the deviant tooth geometry.
I received a letter from Mr. G. W. Richmond, Sullivan Machinery Company, N.H., in which in addition to correcting
mistyping, he made several suggestions
concerning my article "General Equations
for Gear Cutting Tool Calculations."
