Verisurf Software, Inc. will be demonstrating Verisurf 2023 at Control, Stuttgart, Germany, May 3 -6, Hall 3, Stand 3312. Verisurf 2023 continues to refine metrology workflows with added features designed to reduce time and improve the efficiency of automated quality inspection and reporting, scanning, reverse engineering, and tool building.
SMT's latest webinar "MASTA Support - Tips, Tricks and FAQ" will take place May 4, 2022. The SMT customer support team receive queries covering all areas of MASTA, with industry 'hot topics' inevitably arising. In this webinar, SMT engineers focus on answering some of the queries that frequently make it into their support inbox.
With its brand-new 300GMS nano Gear Metrology System, Gleason presents a world- first at Control Show 2022, May 03-06, Stuttgart, Germany. The capability of measuring gears at sub-micron level, executing advanced waviness analysis and evaluating gear noise using the most advanced analytical tools, make the 300GMS nano ideally suited to support automotive e-drive production with minimum noise requirements.
At Automate 2022, attendees will have the opportunity to experience how complete, end-to-end automation solutions from KUKA Robotics can help them exceed their production goals.
Hexagon’s Manufacturing Intelligence has released a comprehensive report entitled "Recharging the Automotive Market." The body of work was produced by Hexagon and draws from the original research conducted with Wards Intelligence and Informa Tech Automotive Group (ITAG).
In manufacturing, we all know that
tracking statistics on your operation is
essential for understanding how you're
doing, as well as identifying areas for
improvement. But what does the efficiency
metric actually tell you?
The efficiency of a gearbox is the output energy divided by the input energy. It depends on a variety of factors. If the complete gearbox assembly in its operating environment is observed, then the following efficiency influencing factors
have to be considered
Over the past few months I've talked with several different gear manufacturers who are in the process
of upgrading their gear making equipment
with modern CNC machine tools. Each of these manufacturers has come to the realization that in order to stay competitive, he needs to streamline operations and become more
efficient...
It is widely recognized that the reduction of CO2 requires consistent
light-weight design of the entire vehicle. Likewise, the trend towards electric cars requires light-weight design to compensate for the additional weight of battery systems. The need for weight reduction is also present regarding vehicle transmissions. Besides the design of the gearbox housing, rotating masses such as gear wheels and shafts have a significant impact on fuel consumption. The current technology shows little potential of gear weight reduction due to the trade-off between mass optimization and the manufacturing process. Gears are usually forged followed or not by teeth cutting operation.
