The purpose of this paper is to present a method of designing and specifying gear teeth with much higher bending and surface contact strength (reduced bending and surface contact stresses). This paper will show calculation procedures, mathematical solutions and the theoretical background equations to do this.
IMTS exists primarily as a buy-and-sell
North American venue for practically every conceivable technology used in manufacturing, and in that regard it has no equal. There you’ll find on display the latest and greatest technology, from hardware to software and everything in between. But anyone who has attended past shows is aware that IMTS is much more than that. Following is a rundown of "extracurricular" activities you’ll find waiting for your edification
and enjoyment.
The efficient and reliable transmission of mechanical power continues, as always, to be a central area of concern and study in mechanical engineering. The transmission of power involves the interaction of forces which are transmitted by specially developed components. These components must, in turn, withstand the complex and powerful stresses developed by the forces involved. Gear teeth transmit loads through a complex process of positive sliding, rolling and negative sliding of the contacting surfaces. This contact is responsible for both the development of bending stresses at the root of the gear teeth and the contact stresses a the contacting flanks.
