This study aims to investigate the effect of this identified type of shot peening on the micropitting resistance of the gear tooth flanks and the macropitting resistance and to compare the experimental results with the calculation results based on standard methods.
In the KISSsoft shaft calculation, the proof of fatigue strength can be performed by generating an equivalent stress verification according to the FKM Guideline.
A new version of the MESYS shaft and rolling bearing analysis software including new functionality is available. The bearing analysis software allows the calculation of the load distribution within the bearing and bearing life according to ISO/TS 16281 and it is integrated in a shaft system calculation with additional possibilities like modal analysis, strength calculation for shafts and interfaces to gear calculations. Currently the software is used by customers in 30 countries on four continents.
SEGULA Technologies and British scale up Senseye, specialized in predictive maintenance based on artificial intelligence, have announced the signing of a partnership.
SMT's May workshops aim to give attendees the tips and tricks needed to further improve the fidelity of the MASTA model. In this workshop, SMT engineers will go through some of the tools available including:
SMT's latest webinar "MASTA Support - Tips, Tricks and FAQ" will take place May 4, 2022. The SMT customer support team receive queries covering all areas of MASTA, with industry 'hot topics' inevitably arising. In this webinar, SMT engineers focus on answering some of the queries that frequently make it into their support inbox.
