Planetary Gears: A Few More Things July 16, 2018 Charles D. Schultz No Comments Before we move...Read More
Planetary Drives: The Same but Different July 5, 2018 Charles D. Schultz No Comments Those ancient planetary drives I first got involved with in 1979 (Read More
Parametric Design May 18, 2018 Charles D. Schultz No Comments One of the scariest things a gear designer can face is a blank sheet of paper. This is why most of our products are “derivative” rather than “revol...Read More
Bending the Rules May 1, 2018 Charles D. Schultz No Comments In my last posting I advised designers to avoid relying on “rules of thumb” or computer coding when confronted with tough decisions. This admonitio...Read More
How Much Helix Angle? April 3, 2018 Charles D. Schultz No Comments The most obvious difference between a spur gear and a helical gear is the presence of that “helix” angle. Civilians will call them “straight-cut” a...Read More
Department of Corrections November 28, 2017 Charles D. Schultz No Comments It was brought to my attention that the graphics used in my recent “herringbone” postings actually show double helical gears. I have a great suppor...Read More
KISSsoft Calculations Include Splines, Springs and Plain Hydrodynamic Bearings September 22, 2017 KISSsoft's spline calculation now also includes a new function for calculating the strength of involute splined joints according to A...Read More
KISSsoft 03/2017 Release Allows Users to Evaluate Reliability of Gear Units, Individual Gears and Rolling Bearings August 23, 2017 A function in KISSsoft Release 03/2017 enables you to evaluate the reliability of gear units, individual gears and rolling bearings. ...Read More
Gear Teeth as Bearing Surfaces May 1, 2017 A reader wonders about gears where the tops of the teeth are the bearing surface, as used in spur gear differentials. Do they require any special construction or processing?Read More
