I'd like to share with you a vision of the future. It takes place in cyberspace, and it's coming soon to a computer near you. Whether you like it or not, and whether you're ready or not, the Internet is changing the way business is conducted.
The first part of this article describes the analytical design method developed by the author to evaluate the load capacity of worm gears.
The second part gives a short description of the experimental program and testing resources being used at CETIM to check the basic assumptions of the analytical method; and to determine on gears and test wheels the surface pressure endurance limits of materials that can be used for worm gears.
The end of the article compares the results yielded by direct application of the method and test results.
In the May/June Issue of your excellent magazine. Mr. Stan Jakuba discusses a serious problem, not only for the gear industry, but any machinery where fluctuating torque is encountered.
I would like to make the following comments to his article...
How important is the right choice of coupling in determining successful machine design? Consider the following
example. A transmission of appropriate size was needed to transfer the speed of the engine driver to that of the driven generator. The transmission was properly selected and sized to endure the rated power requirements indefinitely, but after only a short time in operation, it failed anyway. What happened? The culprit in the case was a coupling. It provided the necessary power and protection against misalignment but it lacked the ability to isolate the gears from the torque
peaks of the diesel engine.
