Bearings ain't beanbag. They are complicated. They are big-business. They are often counterfeited. They are used in virtually anything that moves.
But it is the "complicated" part that
challenges OEMs, job shops and other
operations, and, most of all, their
employees. Add to that the countless
other entities around the world that are
intimately involved with bearings and
you can arrive at a semblance of an idea
of just how important these precious
orbs can be to a successful operation.
It’s a brave, new hardware-software world out there. Players in the worldwide gear industry who don’t have plenty of both run the risk of becoming irrelevant—sooner than later.
In November, Gear Technology conducted
an anonymous survey of gear manufacturers. Invitations were sent by e-mail to thousands of individuals around the world. More than 300
individuals responded to the online survey, answering questions about their manufacturing operations and current challenges facing their businesses.
in this area.
The great thing about a trade show the size of IMTS is the amount of options available to attendees. If you’re into cars, fighter jets, machine tools,
fighting robots, manufacturing relics or
simply the latest technology advancements in a particular industry, you’ll find it at IMTS 2010.
In this article, gear buyers have been given an opportunity to discuss quality, value, customer service and how gear manufacturers can improve business practices.
