years ago.
India is rapidly turning into a global manufacturing hub, thanks to the country’s manufacturing and engineering
capabilities, vast pool of skilled expertise and its size. These qualities offer it a strategic advantage for the manufacturing segment. A large number of international companies in varied
segments have already set up a manufacturing base in India and others are following suit. It only makes sense to bring this industry segment together under one roof to discuss the current
trends and technology prevalent to the marketplace. IPTEX 2012 is scheduled from February 9–11, 2012 at the Bombay Exhibition Center in Mumbai, India.
Involute spline couplings are used to transmit torque from a shaft to a gear hub or other rotating component.
External gear teeth on the shaft engage an equal number of internal teeth in the hub. Because multiple teeth engage
simultaneously, they can transmit much larger torques than a simple key and keyway assembly. However, manufacturing
variations affect the clearance between each pair of mating teeth, resulting in only partial engagement.
This paper presents a unique approach and methodology to define the limits of selection for gear parameters. The
area within those limits is called the “area of existence of involute gears” (Ref. 1). This paper presents the definition and construction of areas of existence of both external and internal gears. The isograms of the constant operating pressure
angles, contact ratios and the maximum mesh efficiency (minimum sliding) isograms, as well as the interference
isograms and other parameters are defined. An area of existence allows the location of gear pairs with certain characteristics. Its practical purpose is to define the gear pair parameters that satisfy specific performance requirements before
detailed design and calculations. An area of existence of gears with asymmetric teeth is also considered.
Conical involute gears, also known as beveloid gears, are generalized involute gears that have the two flanks of the same tooth characterized by different base cylinder radii and
different base helix angles.
