Surface Combustion is a leader in controlled atmosphere heat treating furnaces and atmosphere generators. Learn detailed information about heat treat atmospheres including, descriptions, compositions, generation methods, and applications. This is a fantastic resource for heat treat operators, metallurgists, and maintenance technicians
Surface Combustion is a leader in controlled atmosphere heat treating furnaces and atmosphere generators. Learn detailed information about heat treat atmospheres including, descriptions, compositions, generation methods, and applications. This is a fantastic resource for heat treat operators, metallurgists, and maintenance technicians. Contact Surface Combustion to discuss your specific requirement.
Uncover the processes and furnaces used for the steel case hardening solutions. Ben Bernard from Surface® Combustion, Inc. describes these options and reveals the advantages and disadvantages of the various options.
Ferritic Nitrocarburizing (FNC) and Nitriding improve wear, corrosion, and fatigue properties by processing in furnaces at lower temperatures while minimizing distortion. Learn more from Ben Bernard at Surface® Combustion, Inc.
