Traditionally, gear rating procedures consider manufacturing accuracy in the application of the dynamic factor, but
only indirectly through the load distribution are such errors in the calculation of stresses used in the durability and gear strength equations. This paper discusses how accuracy affects the calculation of stresses and then uses both statistical
design of experiments and Monte Carlo simulation techniques to quantify the effects of different manufacturing and
assembly errors on root and contact stresses.
The contact lines of a pair of helical gears move diagonally on the engaged tooth faces and their lengths consequently vary with the rotation of the gears.
