Faithful Addendum readers are accustomed to finding upbeat, whimsical and oddball stories about gears in this
space. What follows is not about gears, exactly. Rather, it is, as opposed to the usual bleak news about America losing its manufacturing mojo—a look at a positive, hopeful development in that regard.
in this area.
A series of bench-top experiments was conducted to determine the effects of metallic debris being dragged through meshing gear teeth. A test rig that is typically used to conduct contact fatigue experiments was used for these tests. Several sizes of drill material,
shim stock and pieces of gear teeth were introduced and then driven through the meshing region. The level of torque required to drive the “chip” through the gear mesh was measured. From the data gathered, chip size sufficient to jam the mechanism can be determined.
