In this study, limiting values for the load-carrying-capacity of fine-module gears within the module range 0.3–1.0 mm were determined and evaluated by comprehensive, experimental investigations that employed technical, manufacturing and material influence parameters.
The global wind energy market has seen average growth rates of 28 percent over the last 10 years, according to the Global Wind Energy Council (GWEC), creating major challenges for the component supply industry. GWEC also forecasts an average growth rate of 22 percent for the next five years, which if realized, will continue to put pressure on suppliers of turbine components.
In this article, equations for finding profile and base pitch errors with a micrometer are derived. Limitations of micrometers with disc anvils are described. The design of a micrometer with suitable anvils is outlined.
Noncircular gearing is not new. There are well-documented articles covering standard and high order elliptical gears, sinusoidal gears, logarithmic spiral gears, and circular gears mounted eccentrically. What these designs have in common is a pitch curve defined by a mathematical function. This article will cover noncircular gearing with free-form pitch curves, which, of course, includes all the aforementioned functions. This article also goes into the generation of teeth on the pitch curve, which is not usually covered in the technical literature. Needless to say, all this is possible only with the help of a computer.
