India is rapidly turning into a global manufacturing hub, thanks to the country’s manufacturing and engineering
capabilities, vast pool of skilled expertise and its size. These qualities offer it a strategic advantage for the manufacturing segment. A large number of international companies in varied
segments have already set up a manufacturing base in India and others are following suit. It only makes sense to bring this industry segment together under one roof to discuss the current
trends and technology prevalent to the marketplace. IPTEX 2012 is scheduled from February 9–11, 2012 at the Bombay Exhibition Center in Mumbai, India.
in this area.
The great thing about a trade show the size of IMTS is the amount of options available to attendees. If you’re into cars, fighter jets, machine tools,
fighting robots, manufacturing relics or
simply the latest technology advancements in a particular industry, you’ll find it at IMTS 2010.
1984 by the author
