The new KISSsoft release 2024 is coming soon! This April will bring you the new system module KISSdesign, accelerating the calculation of complex drive trains and replacing the previous KISSsys software.
With the release of version 9, the FVA-Workbench once again sets new standards in gearbox design, enabling the seamless integration of the latest research results into industrial practice. As a groundbreaking interface between collective research and application, the FVA-Workbench accelerates development and innovation in drive technology. This new release is more powerful than ever, with innovative features for flexible load spectra and improvements in FEM components and shaft-hub connections.
A good 20 years have passed since the web-based calculation software eAssistant saw the light of day in the digital world. The software is probably the oldest commercial online solution for the design, recalculation and optimization of machine elements such as shafts, bearings, shaft-hub connections, gears, bolted joints, springs, etc. The calculations are based on internationally accepted standards and guidelines as well as technical literature.
In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
In an urgent assignment, a gear has to be designed, with the engineer already knowing the required reduction ratio, torque and speed. On the manufacturing side, the preferred materials, possible qualities and the reference profiles are specified. This initial situation represents an everyday task.
The new KISSsoft release 2023 comes with numerous novelties. Among others, Gear Mesh Frequencies (GMF) can now be calculated for cylindrical and bevel gears. GMF results are visualized in two different diagrams, i.e. GMF versus rotational frequency of the reference gear, and GMF versus amplitude.
Renewable Lubricants presents patented, ultimately biodegradable Bio-E.P. Gear Oils which are ideal lubricating spur, helical, bevel, and worm gears subject to heavy loading or shock loading in heavy-duty applications.
GWJ Technology GmbH has extended the output option of tooth forms of involute gears. GWJ has extended the output of tooth forms in 2D DXF format in its calculation modules single cylindrical gears, cylindrical gear pairs, planetary gear trains, three- and four-gear train systems, gear racks and involute splines as part of the new versions of its calculation solutions eAssistant and TBK.
KHK USA Inc. announces its extensive selection of miter gears. These gears are available in high precision grades to perform at demanding torques and speeds, and they are also available in commercial grades for economical applications.
Mahr Inc. recently introduced a new generation of electronic digital comparators, the Millimess 2000 W(i) and 2001 W(i).The new digital comparators combine practical and reliable operation with maximum precision. Using a unique inductive measuring system, measurements are more precise than ever with added probe linearization—whether it’s a static or dynamic measurement task.
