In a capitalist society, the way things usually work is that government
and academia focus on research and
development, while industry focuses
on commercialization. The result
is an increasingly wide disconnect in
the applied research sector, which deals
primarily with technology development
and demonstration.
The auction has been held. The warehouse is bare. The computers
and furniture are being packed, and Cadillac Machinery, the company
started by my father in 1950, and of which I was president for more
than 25 years, is close to being no more.
Information is the name of the game in the 90s. We need more of it; we need it faster; and we need it in infinitely manipulatable and user-friendly form. In many cases, getting it that way is still something of a Holy Grail, somewhere off on the distant horizon. But thanks to computer technology, bit by byte, we're getting there.
This article discusses an application driven approach to the computer-aided sizing of spur gear teeth. The methodology is bases on the index of tooth loading and environment of application of the gear. It employs handbook knowledge and empirical information to facilitate the design process for a novice. Results show that the approach is in agreement with the textbook data. However, this technique requires less expert knowledge to arrive at the conclusion. The methodology has been successfully implemented as a gear tooth sizing module of a parallel axis gear drive expert system.
techniques.
