Almost any external tooth form that is uniformly spaced around a center can be hobbed. Hobbing is recognized as an economical means of producing spur and helical gears with involute tooth profiles.
In order to increase the load carrying capacity of hardened gears, the distortion of gear teeth caused by quenching must be removed by precision cutting (skiving) and/or grinding. In the case of large gears with large modules, skiving by a carbide hob is more economical than grinding when the highest accuracy is not required.
