Toyoda's new GS300H5 Gear Skiving Center is the first in the world to equip a skiving function to a general purpose horizontal machining center (HMC), through which mass production of gear parts is achieved. CNC controls and a high speed rotary table were developed specifically to achieve high-speed, multifunctional machining, as a compact and lightweight product, simple in programming functions.
Skiving will be front and center when the gear industry comes together in Columbus this October. Attendees will find dedicated skiving equipment, multifunctional machines with skiving options and a slew of new cutting tools, machine designs and modifications to make the process more efficient and robust.
RCD Engineering's switch from manual to CNC hobbing operations breaks gear manufacturing lead time records with
Bourn & Koch 100H in their gear production pit crew.
AGMA Sets Up Shop in Living Laboratory of the Midwest. Columbus, Ohio recently surpassed Indianapolis as the second largest city in the Midwest behind Chicago, according to the United States Census Bureau. This could change come the
2020 census, but there's no denying
Buckeye Nation is going places.
Gear hobbing is one of the most productive manufacturing processes for cylindrical gears. The quality of the gears is a result of the tool quality, the precision of the workpiece, tool clamping and kinematics of the machine. The dry gear hobbing process allows machining of gears with a quality according to the DIN standard up to IT 5. To evaluate which gear quality is possible to machine with a given clamping and hob, it is useful to simulate the process in advance.
