In order to produce high-performance cutting tools, tool manufacturers go to great lengths to get all manufacturing parameters right. Production conditions have tremendous influence on the final quality of the tool...
Sunnen's new HTE honing system, the company's most cost-effective small-diameter hone, produces ideal bore geometry and surface finish, while eliminating problems from bad tool-to-part alignment...
