I would like some instructions for setting the degrees and minutes on a Liebherr
or Barber Colman hob. Our machines use a Vernier scale to match the lead angle
of the cutter to the part to form straight teeth. There is a dispute on how to do
this task, and I wanted insight from another professional.
Decades ago, technology shifted from HSS to indexable inserts in turning and milling. This movement wasn't immediately realized in gear hobbing because coated PM-HSS hobs and complex gear profiles remained highly effective and productive methods. Only fairly recently have gear manufacturers started to take a serious look at indexable technology to cut gear teeth.
