This article presents some of the findings of cutting investigations at WZL in which the correlation of cutting parameters, cutting materials, tool geometry and tool life have been determined.
Gear Technology was founded 22 years ago on a very simple principle: to provide the best possible educational articles and information for the gear industry.
