Easily one of the central issues
affecting U.S. manufacturing is what one might call the exports deficit—the inability of American companies to sell products to, for instance, Asian markets, developing countries and other ports of call—due to what they perceive to be unfair trade agreements and or policies.
The machine element package by KISSsoft for the design and optimization of components like gears, shafts, bearings and others is now available in the new version 04/2010.
What do glam and avant garde rock star Brian Eno, AGMA and Seattle Gear Works have in common? Admittedly, not much. But there is a connection of sorts.
