We are well into an odd-number year, so it must be just about time for another Gear Expo. Indeed, the big show -- Gear Expo 2013 -- kicks off in Indianapolis at 9:00 a.m. Tuesday, September 17, wrapping up Thursday the 19th at 4:00 p.m. And whether you are exhibiting or attending, the bottom line is you are going -- a good thing for you, your company and the tightly knit U.S. gear industry.
It’s been said that the best ideas are often someone else's. But with rebuilt, retrofitted, re-controlled or remanufactured machine tools, buyer beware and hold onto your wallet. Sourcing re-work vendors and their
services can require just as much homework, if not necessarily dollars, as with just-off-the-showroom-floor machines.
The machine element package by KISSsoft for the design and optimization of components like gears, shafts, bearings and others is now available in the new version 04/2010.
What do glam and avant garde rock star Brian Eno, AGMA and Seattle Gear Works have in common? Admittedly, not much. But there is a connection of sorts.
