There are many key performance gains when retrofitting a gear-cutting machine originating from the 1960s and 1970s. First, it can be noted that the new retrofitted CNC machine performs the same machining operations as the conventional mechanical machine, but - quite clearly - with an exponentially higher output. This is thanks to a reduction in set-up and production time and with a significantly higher quality of the finished gear.
Bharat Gears Ltd., one of India’s largest gear manufacturers, has successfully retrofitted a Reishauer RZ361A gear grinding machine with an advanced NUM Flexium+68 CNC system.
Machine Tool Builders Inc. (MTB) has added a high-speed, high-precision Chamfering and Deburring Machine to its family of new gear production machines.
An economical modernization program gives
Designatronics' tried-and-true Gleason No. 102 Coniflex generators a new lease on life for fast, reliable production of smaller precision straight bevel
gears.
I'd like to apologize to the dedicated people working on revisions to the AGMA 925 standard and the Technical Report ISO 15144-1, both of which deal with the issue of micropitting. In the
March/April issue of Gear Technology, we published an opinion piece in our Voices column that harshly criticized the methods for predicting micropitting outlined in ISO 15144-1.
