Nowadays, finish hobbing (which means that there is no post-hobbing gear finishing operation) is capable of producing higher quality gears and is growing in popularity.
Quality gear manufacturing depends on controlled tolerances and geometry. As a result, ferritic nitrocarburizing has become the heat treat process of choice for many gear manufacturers. The primary reasons for this are:
1. The process is performed at low temperatures, i.e. less than critical.
2. the quench methods increase fatigue strength by up to 125% without distorting. Ferritic nitrocarburizing is used in place of carburizing with conventional and induction hardening.
3. It establishes gradient base hardnesses, i.e. eliminates eggshell on TiN, TiAIN, CrC, etc.
In addition, the process can also be applied to hobs, broaches, drills, and other cutting tools.
The grinding of gears with dish wheels (Maad type grinding machines) is widely viewed as the most precise method of gear grinding because of the very short and simple kinematic links between the gear and the tool, and also because the cutting edges of the wheels represent planar surfaces. However, in this grinding method, depending on the parameters of the gears and one of the adjustments (such as the number of teeth encompassed by the grinding wheels), so-called overtravel at the tip or at the root of the teeth being ground generally occurs. When this happens, machining with only one wheel takes place. As a result, the profile error and the length of the generating path increases while productivity decreases.
Powder metal. To gear makers today, the phrase conjures images of low power applications in non-critical systems. As powder metal technology advances, as the materials increase in density and strength, such opinions are changing. It is an ongoing, evolutionary process and one that will continue for some time. According to Donald G. White, the executive director of the Metal Powder Industries Federation, in his State-of-the-P/M Industry - 1999 report. "The P/M world is changing rapidly and P/M needs to be recognized as a world-class process - national, continental and even human barriers and prejudices must be eliminated - we must join forces as a world process - unified in approach and goals."
The cutting tool industry has undergone some serious changes in the last couple of years in both technology and the way the industry does business. The emerging technology today, as well as for the foreseeable future, is dry cutting, especially in high volume production settings. Wet cutting continues to be as popular as ever with lubrication advances making it more economical and environmentally friendly. There has also developed a process called "near dry cutting." this process offers many of the benefits of fluids while eliminating many of hte associated problems.
I'd like to share with you a vision of the future. It takes place in cyberspace, and it's coming soon to a computer near you. Whether you like it or not, and whether you're ready or not, the Internet is changing the way business is conducted.
