One way to implement the growing performance requirements for transmissions is by optimizing the surface finish of the gearing. In addition to increasing the flank load capacity and the transmittable torque, this also allows for improvements in efficiency. On Oerlikon bevel gear grinding machines from Klingelnberg, fine grinding
can be implemented efficiently in bevel gear production - even in an industrial serial process.
This paper outlines the basic principles of involute
gear generation by using a milling cutter;
the machine and cutting tool requirements; similarities
and differences with other gear generative methods; the cutting strategy; and setup adjustments options. It also discusses the applications that would benefit the most: for coarse-pitch gears the generative gear milling technologies offer improved efficiency, expanded machine pitch capacity, decreased cutter cost, and a possibility for reducing the number of machining operations.
