Gleason Announces Hobbing Machine with Integrated Chamfer Hobbing October 19, 2018 The new Genesis 160HCD Hobbing Machine for cylindrical gears integrates a newly developed process for chamfer cutting. Chamfer Hobbing ...Read More
Liebherr Introduces New Gear Grinding Machine October 19, 2018 Based on its LGG 280 generating grinding machine, Liebherr recently presented the larger LGG 400 M model at IMTS in Chicago. The new L...Read More
Kennametal Releases Latest Helical Milling Cutter October 17, 2018 Kennametal recently released its newest helical milling cutter, the Harvi Ultra 8X.Using a 95 mm (3.74 in.) axial depth of cut, 20 mm (...Read More
Acceptable Fixes September 27, 2018 Charles D. Schultz No Comments You do not always have to say “no” when confronted with non-conforming parts. Here are a few “fixes” I have been comfortable authorizing: Read More
Norton | Saint-Gobain Increases Grinding Productivity with Winter Vitrified CBN Wheels September 21, 2018 Saint-Gobain Abrasives has announced the introduction of its new Norton Winter Vitron7 cBN Grinding Wheels. The wheels feature a high-p...Read More
Adjust Tolerances or Expectations? September 19, 2018 Charles D. Schultz No Comments There is a great deal of science involved in measuring things, but considerably less on what the baseline dimensions and clearances should be. This...Read More
Grinding Machines Increase Quality and Productivity at Nixon Gear September 18, 2018 Two new grinding machines were recently added to production at Gear Motions’ Nixon Gear Division in Syracuse, NY.The Studer S121 is...Read More
The Usual Suspects September 14, 2018 Charles D. Schultz No Comments Once you accept that “stuff” happens in even the best of machine shops, you can begin to assess where the problems are likely to occur and start th...Read More
Something is not Right Here September 7, 2018 Charles D. Schultz No Comments Another benefi...Read More
Hainbuch Taps Hänel for Mandrel Prototype Test September 5, 2018 Matthew Jaster No Comments Hard work and first-class teamwork between the gear factory Hänel and Hainbuch has paid off. The new mandrel Mando G211 for gear manufacturers, sui...Read More
