C&B Machinery (C&B) announced the completion of their newly redesigned Clamp Bore Face Grinding Machines. After months of planning, redesigning, and building the machines, C&B is excited to announce the latest CBVR-2F-2S model Clamp Bore Grinders.
The Big Kaiser EWA Automatic Fine Boring System from Big Daishowa performs closed-loop boring operations without a human operator. This breakthrough eliminates the need to stop the spindle to manually adjust the boring tool, which results in considerable time savings. Also, eliminating human interaction reduces cost, improves accuracy, and minimizes scrap. The adjustment range of this fine boring head allows for the handling of multiple bore sizes with the same tool and ensures a repeatable boring process.
The honing of gears - by definition
- facilitates ease of operation, low noise and smoother performance in a transmission. Honing also contributes to
reduced friction in the powertrain. Both the intense cutting (roughing process) as well as the functionally fine- finishing of transmission gears can be performed in one setup, on one machine.
Stringent NVH requirements, higher
loads and the trend towards miniaturization to save weight and space are forcing transmission gear designers to increasingly tighten the surface finish, bore size and bore-to-face perpendicularity
tolerances on the bores of transmission
gears.
