The transition to EVs will lower transport emissions, and adoption can be accelerated by increasing their efficiency. EVs that take advantage of aluminum components can travel further per charge, helping to overcome range anxiety. Automotive manufacturers who select machining tools optimized for aluminum will be able to produce high-quality aluminum EV components ― helping to support the shift to greener travel.
Spur cylindrical gears are usually cut using a hob and therefore present an essentially straight face to which crowning can be added to prevent edge contact. Rather than using a rack or hob, it is possible to cut cylindrical gears with a face mill cutter. In the following presentation, these gears are termed "spurved," i.e. — a contraction of "spur" and "curved."
